Question about IBM System Storage TS3200 Tape Library Model L3H - Tape library - 17.6 TB / 35.2 TB - slots: 44 - LT... (3573L3H) Tape Drive
Elevator blocked code 8b35 - IBM System Storage TS3200 Tape Library Model L3H - Tape library - 17.6 TB / 35.2 TB - slots: 44 - LT... (3573L3H) Tape Drive
Error code E 7
proceed according you have two alternative: see the diagrams . God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jan 22, 2013 | LifeSpan Fitness Lifespan PRO3 -Treadmill-...
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
2)Alternative:
Jan 08, 2013 | Tunturi T40 Folding Treadmill
Treadmill Protec Forerunner 3000 E 7 light on (mother control board FH-3545C-E, VER:B2)
Step 1:
you will have two alternatives:
ERROR CODE # 7
2)Alternative:
see the block diagram+additional diagrams for troubleshooting and fix it.
God bless you
Step 2:
1_4_2013_6_15_26_pm.jpgelevation motor diagram
Step 3:
treadmill motor control board diagram
Jan 04, 2013 | Sportcraft Exercise & Fitness
Error7 on ht402
see the 2 alternatives. and proceed for fix it. God bless you
ERROR CODE # 7
2)Alternative:
Dec 13, 2012 | Exercise & Fitness
Treadmill KETTLER PACER error code E7, what I have to do?
see the next steps and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 28, 2012 | Kettler treadmill Pacer
Error code e7 on trojen staminia 310 - already tried switching off and on again. I washed machine and mistakenly got the motor wet.
see the next steps. God bless you
ERROR CODE # 7
2)Alternative:
Nov 16, 2012 | Exercise & Fitness
I HAVE POWERTREK STRIDER IS NOT WORKING WHAT WILL I DO
see the next causes and remedy and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 13, 2012 | Treadmill Doctor Nordictrack Powertread...
What means error 07 by HAMMER walkrunner? how can i resolve that?
means 2 options:God bless you
ERROR CODE # 7
2)Alternative:
Oct 08, 2012 | Hammer Walkrunner Rpe Treadmill
What is error e7?
This error means 2 alternatives : a) elevation motor NOT working + b) display not working too.
However you are mention that after 3 seconds the machine goes stop.This reveal that you must to do the following:
1) LUBE the deck belt very well, lack of maintenance shut down the machine for protection.
2) LUBE the rollers bearing,too
3) test the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are not the board is faulty.
1) alternative for error codeLa) elevation motor LUBE the gear and shafft and adjus the pot.,tight any wires connector and clean
2) alternative for error code 7 b) adjust the REED switch, clean and tight the wires connector very well. see the block diagram
after you fix RUN the software calibration for diagnose, troubleshooting and fix it.
God bless you
7_17_2012_10_13_08_am.jpg7_17_2012_10_13_31_am.jpg7_17_2012_10_14_05_am.gif7_17_2012_10_14_22_am.gif
Jul 17, 2012 | Tunturi T30 Treadmill
Healthstream Elation HS 2200T - E3 code - incline not working
1) Lube the shaft and gear from elevation motor
2) Tight the connection motor very well.
3) Adjust the potentiomenter from elevation motor
4) Measure the voltage input.
5) Try to RUN the software calibration for diagnose, and troubleshooting see the block diagram.
God bless you
Jun 13, 2012 | Exercise & Fitness
IBM System Storage TS3200 Tape Library Model L3H - Tape library - 17.6 TB / 35.2 TB - slots: 44 - LT... (3573L3H) Tape Drive Logo
433 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
