Sony Handycam® DCRSR45  HDD Camcorder Logo
A
Anonymous Posted on Nov 21, 2013
Lcd screen not working - Sony Handycam® DCRSR45 HDD Camcorder
Black web hdmi splitter won't work,with my vizio tv
Maybe the tv main board problem,or the HDMI interface out of works
Abctay.com Wholesale tv parts,include TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Hi,have a 60 inch plasma lg tv some 6yrs old or so and the picture has gone out but still have sound,any ideas?
screen out of works.
2answers
TV no longer power's on. What problem is causing this condition?
If the TV AND the DVD player are not powering on, then it sounds like the problem is at the receptacle or power strip, where the TV and the DVD player are plugged in. Make sure the receptacle or power strip is working. Plug something else in, a lamp, a radio, anything, and see if it works. If it doesn't then the power strip is off or not working or the wall receptacle is not working.
A friends laptop is only showing a white screen
Step 1:
Fix a White Screen on an LCD Monitor
b>When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance.
b> b> b> Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video. For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen. After I assembled everything back together and connected the original LCD, it's still white. CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced. b> b>
My pc is showing a white screen when iys on
Is it an LCD monitor ?
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See Below for the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance. Hope this helps.
Sidekick lx screen went blank isnt working..
You can try to reseat the lcd cable and make sure it is tight. It that fails then you will need to replace the LCD screen
Here are instructions for replacing the Sidekick LX screen: How to replace the Sidekick LX LCD Screen
and here is a link to the LCD screen son ebay.
Sidekick LX LCD Screens
2answers
Lcd light
More than likely you will need to replace the LCD screen. The backlight may have burned out making it blank.
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
The W580i LCD screen is very easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony W580i LCD Screen Replacement
I hope that helps you out
2answers
Broken Screen
most are. you need to open the lcd and get the model number from the back of the lcd itself. you will need manufacturer, model number and revision number.
if the glass is not cracked, you may simply need a new backlight.
LCD lights up, but is blank when i open the flip
yeah that is possible. make sure you know what you are doing and don't damage the working LCD screen it might just be easier to replace the whole cuircuit board that the LCD screen is on.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
