Question about Frigidaire GLTF2940ES Front Load Washer
Black finish Hi. The black finish on the top of my new washer and dryer are filled with scratches, just from basic use. I was told (after purchasing the appliances) that the white finish is baked in, but the black is painted, thus the problem. Anyone had this problem and know of a solution, other than re-painting?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Depending on how deep a good cutting compound/polish should do the trick...be careful the paint might be quite thin
Posted on Jan 01, 2008
SOURCE:
Tip
A quick fix for CDs that skip or sound scratchy
I was told to use toothpaste - and it worked! Rub toothpaste on your scratched CD - over the entire thing. Then rub off with dry cloth/rag til smooth. Though it looks like all the paste has come off, it has actually filled in some of the micro scratches. Try to play cd - it has worked for me numerous times.
Also, on these CDs - or any old ones - upload into your computer (the computer doesnt pick up as many scratches as a basic cd player). When finished uploading (this could be called "ripping" with Windows Media Player or "importing" on ITunes, your computer now has all songs. Put in blank disc and "burn" onto a new CD. Its like it was brand new again!
on Jun 14, 2010 | Audio Players & Recorders
How remove wash machine top
On these machines there are no screws holding the top down, get under it and pop it up using a tool that won't scratch the finish.
First I would try removing the front panel to see if it could be done through the front. Its only held by two screws in the bottom.
Good Luck
Quentin
Sep 29, 2009 | Frigidaire FEX831CS Top Load Stacked...
Water won't dump
When you replace the pump, always to remember to makes sure the pump is pushed all the way in so that the shaft has a good grip. Try taking it out and pushing it all the way in. The 4 legs should touch the motor, as you put the 2 little clamps on the top and bottom.
Good luck, I'm pretty sure it's something really basic with the pump :)
Jul 19, 2009 | Whirlpool LTE6234D Top Load Stacked...
Grease stains from Maytag MAV7200AWW washer
HI! I just posted a question to "justask.com" and am having the exact same problem. I paid $9 for this answer and was happy to pay it because I now know what it is! From what I have been told, it is from the transmission in your washer and will cost at least $400 to fix it (that's just a ballpark figure... I have a Frigidaire and that was the figure I was given). So, basically, it would be more cost effective for you to purchase a new washer.
Apr 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Trying to trouble shoot problem with Frigidare stack top load was
There are 2 screws on the bottom/front of the cover to the washer. Remove the screws. Near the top/front of the cover is a seam; insert something flat in the seam (such as a screw driver blade, covered as to not scratch the finish)and pry the cover downward. This worked for me.
Jan 28, 2009 | Frigidaire GLET1031 Top Load Stacked...
Whirlpool Duet frontloader washer's dispenser stays filled
I had a similar problem, but mine was with the detergent side. I removed the top of the washer and had to clean the dial that advances to let the cyle of dispensing continue. It worked, but now the machine shakes and I am told is 'unbalanced'
Jan 16, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Fills with water and that's it
ck the water pump, only if it agitates but doesnt drain. If it completely stops after filling, ck lid switch(should here clicking noise from sw.)
Oct 21, 2008 | Frigidaire FEX831CS Top Load Stacked...
Scratched top. Need part number?
assuming the very top cover on both units are scratched??? i have part numbers for you , but thinikin your gonna need to call cust service to order the parts, local part houses probably dont stock them(lg parts anyway).. washer part number( AGU30781501 $80US) dryer part number ( AGU30071202 $70 US)
May 10, 2008 | LG WM2487H Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
115 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
