Question about Dell Inspiron 6400 Notebook
Usb 3g modem disconnecting
Have Hauwi E220 3 g modem , after numerous attempts got the software installed and drivers..but it will not connect it trys and then disconnects after a couple of seconds.. am tearing my hair out..Have vista on the machine
  • 4,889 Answers
Re: usb 3g modem disconnecting
Dear dinny you modem was not compatible with windows.Very recently a driver has been released for Vista.For the complete procedure and the driver click on the link below..
Posted on Oct 09, 2007
I have the same problem with Windows XP Pro SP3
Posted on Jun 19, 2009
Bonixbae, problem anda bukan pada modemnya (pastikan bahwa seluruh setting modem sudah sesuai), karena saat ini indosat m2 memang sedang bermasalah berat, jadi menurut saya problem nya ada di provider anda, coba anda pergunakan kartu yang lain (terlkomsel flash, xl, axis) untuk mengecek modem anda, kalau tidak bisa juga/tidak ok baru periksakan modem anda
joko (
Posted on May 06, 2009
Saya pemakai modem jenis huawei E220... kecepatan internet nya kok lambat ya... saya pake indosat M2.. mohon petunjuk supaya speed internetnya jadi oke.makasih
Posted on Mar 19, 2009
0 characters
3 Points
I have a gateway computer well Iwas using my kyocera rise as a modem well my house power surged and I had to trade it in for the same kind but now I can't get the new phone to connect it keeps saying that...
For a "driver problem", access "Add/Remove Programs" and uninstall the software for the Kyocera USB modem.
Shutdown and reboot your computer, and Windows should re-install the correct driver software.
Jun 30, 2014 | PC Laptops
3g modem giving netcard error
I would go back to basics and fristly check the driver is correct, then the id and password (if any). Take a step back.
Dec 03, 2013 | PC Laptops
Toshiba satellite pro l500 2011 Tear down access the 3G blue motherboard add a sim card, How to enable its laptop to internet capability mod?
If you want to sacrifice your wireless then technically this could work. The wireless card is generally connected via 2 wires that can be disconnected. If you have a 3G 'card' with the same connector to the motherboard, and also if there is software / drivers to work the card in windows, the this may work. A much easier solution would be to purchase a 3G USB dongle.
Apr 17, 2013 | PC Laptops
USB modem device driver software is not successfully installed on my Laptop for windows7.
right click on your my computer and then click on manage
then open device manager from left panel in the opened window
then list of all the hardware will open
be sure you have connected your USB modem already
check your hardware in the list of all hardware.
if its not properly installed then an exclamation mark will be in front of that driver.
right click on that driver then click on update driver software.
complete this procedure
May 20, 2011 | PC Laptops
if you have connected other modems before, that could be due to driver conflicts. have all other modem software uninstalled then install the one you need.
Apr 04, 2011 | PC Laptops
How to install the 3g card in my inspiron n5010 lap.... help me plz
Hi, 3G driver you can download here- 1.Download the 3G driver . 2.Double click the exe file to run it. 3.Follow the instructions given to you. 5. Wheninstallation has completed, the program will open and you can start using 3G without any problem. Good Luck. Thanks for using FixYa.
Feb 27, 2011 | Dell PC Laptops
I have sony vaio vgn-cs14g laptop. i am using tata photon usb internet modem. but suddenly it stoped working and when i installed the photon software ZTE , after connecting the photon modem it is not...
First I am unsure of your OS - (operating system) is it Microsoft Vista? XP? 7?
Besides that, I would go to the Control Panel - uninstall the device driver(s) for the photon software ZTE, and the inbuilt bluetooth and web cam, if they are showing 'installed' but the are NOT working.
Then, ONE at a time, starting with the ZTE, download the most current driver or the last working driver you have. Do not attempt any further installs of drivers until you see this is successful.
Once you have installed the driver, this should either work, or generate a specific error. Please reply with the results and we could go from there!
Thank you!
May 06, 2010 | Sony VAIO Notebook
Windows 7 on aspire one AOA150, built in modem doesn't work
After installing Windows 7 and any other new applications, please ensure that you have loaded ALL the required W7 drivers for your specific Aspire One especially the CHIPSET supports driver (if not, plug-in devices and other inbuilt devices like sound, modem, usb or video will not work properly). Hope it helps. Let me know how you go!
Dec 31, 2009 | Acer Aspire One AOA110-1113 Netbook
I cannot get a 3g USB modem to connect to a Sony Vaio. When the software is loaded the connect button does not change colour and does not respond to a click
First check the device manager to see if there is any conflict between the 3g USB modem and the vaio, then have the Plug & play app in add hardware search for the modem, if it doesnt find it , unplug the modem,while the vaio is running the add hardware app and force the laptop to recognize it. then after it recognizes it make sure vaio has the correct drivers to keep it "talking" to each other, and connect to the modem.
Jul 13, 2009 | PC Laptops
Laptop-dongle connection
Is your "dongle" a 3g modem? 3g modems are often rated at speeds which are practically impossible to reach. Your connection speed will vary depending on the weather, the materials your house is made of and how strong the signal is from the base station. You might notice that your upload speed is especially poor, this is normal for 3g modems. That being said, there are a few things you can do to improve the situation. You can try to get the modem near a window with a better signal, you can install a program like FDM ( which makes a huge difference for download speeds on a g3 modem (I get 50kbps downloads without the program, 400kbps downloads with it). If all else fails you can contact T-Mobile and report a problem with the network - again, it worked for me.
Apr 06, 2008 | PC Laptops
Dell Inspiron 6400 Notebook Logo
1,178 people viewed this question
Top Dell PC Laptops Experts
Sudeep Chatterjee
Sudeep Chatterjee
Donna Sander
Are you a Dell PC Laptop Expert? Answer questions, earn points and help others
