Question about Adobe Acrobat 6.0 for PC
Filling in Adobe Acrobat job applications
I cannot fill in fields in a job application in Adobe Acrobat 4. The on line help method will not work. Dose Adobe Acrobat work or is it a subtle method of frustrating its user? I find it about as user friendly as developing an affectionate relationship with aporcupine! Help! Bill
  • gssidhu_ps Aug 15, 2008
    I HAVE GOT PR FORMS FROM CANADIAN EMBASSY, IT REQUIRES TO BE SAVED IN ADOBE ACRBATE 6.0 STANDARD/PROFESSIONAL I HAVE ADOBE 6.0, BUT YNABLE TO SAVE /EDIT THE SAID FORMS PL HELP ME TO FILL UP THE FORMS I SHALL BE HIGHLY THANKFUL TO YOU.
  • 265 Answers
Most Acrobat forms (your job application for example) are designed to be printed out and the fields filled in by hand. If you create a new form, based on the job application that you've downloaded, you may be able to type in your information in the fields, but it will depend on the security level of the PDF that was created originally. It sounds like the person who designed the form didn't set it up to accept input, merely to be printed out and filled out manually using the first handheld computer: a pencil.
Hope this will FixYa!!!
Posted on Dec 31, 2007
Adobe Acrobat 7.0 Pro Error
Adobe has disabled the activation server for CS2 products, including Acrobat 7, because of a technical issue. These products were released more than seven years ago, do not run on many modern operating systems, and are no longer supported.
Download the New Copy of Acrobat and activate it with the new serial Number .
Click this Link CS2 downloads
Apr 22, 2013 | Adobe Acrobat 7.0 Professional
Tip
Error "the application is being terminated because of memory corruption"
When you exit Acrobat 7, Acrobat returns the error message,"the application is being terminated because of memory corruption."
Solutions
Do one of the following solutions:
Solution 1: Install the Acrobat 7.0.8 update.
If you have Acrobat 7.0, choose Help > Check For Updates Now to install the update. Alternately, you can download the update from the Adobe website at www.adobe.com/downloads/ .
Solution 2: Remove the files from theAcrobat Organizer folder.
When you remove files from the Acrobat Organizer folder, you force Acrobat to rebuild the Organizer database. This process replaces any damaged files in the Organizer that may be causing the error message.
To remove the files from the Acrobat Organizer folder:
1.Choose Start > Run.
2.In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Organizer70.
3.Delete or move all filesfrom this directory.
Solution3: Remove the files from the Updaterfolder.
You may receive this error message after a failed update, indicating that the files in the Updater folder are corrupted.
To remove the files from the Updater folder:
1. Choose Start > Run.
2. In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Updater.
3. Delete or move all the files fromthis directory.
on Mar 20, 2010 | Adobe Acrobat 7.0 Professional
"Pick..." List on the Calculate tab of Text Field Properties in Edit field mode in Adobe Acrobat 10
http://adobe-flash-player-non-ie.soft32.com/ 11.4.402.278Free Adobe Flash Player is a cross-platform browser-based application runtime. Hope this helps.
Jan 18, 2013 | Adobe Acrobat X Pro
How do I create a form field in adobe acrobat pro cs4 that will accept a photo?
Form fields will not accept images. The only way you can add an image is in a pdf that is already created. You have to use the "Paste Clipboard Image as a Stamp".
This is from the Acrobat Help file.
Here are the steps:
You can use the Paste Clipboard Image As Stamp tool to add images to a PDF. You can copy most image formats from drawing and image-editing applications, such as Adobe Photoshop and Adobe Illustrator. If you want to add the image to PDFs repeatedly, create a custom stamp of the image.
Note: The Paste Clipboard Image As Stamp tool isn’t available until you copy an image.
  1. Copy an image by doing one of the following:
    • In Acrobat, choose Tools > Select & Zoom > Snapshot Tool a_snapshot_sm_n.png, and select an image from a PDF.
    • In another application, select an image and choose Edit > Copy.
  2. Open a PDF.
  3. Choose Tools > Comment & Markup > Stamps > Paste Clipboard Image As Stamp Tool.
  4. Click in the PDF where you want the image to appear.
  5. Do any of the following:
    • To move the image, drag it.
    • To resize the image, select it and then drag one of its handles. Press the Shift key when resizing the image to maintain the original proportions.
    • To change the image properties, right-click it and choose Properties.
    • To delete the image, right-click it and choose Delete.
Nov 18, 2009 | Adobe Acrobat 7.0 Professional
I am on windows XP. I have copied a PDF form on to my local disk. PDF document properties indicate that Filling of form fields is allowed yet I cannot fill the form fields. What do I have to do?
Try this first.
Look at your cursor. If it is a Hand, you have selected the hand tool. If not, go and select the Hand tool.
With the "Hand Tool" selected, go over one of the fields that you can type.
1. If the cursor remains as a "Hand", then the fields are NOT fillable. It can be printed, but NOT filled.
2. If the cursor changes from a "Hand" to a vertical line ("I"), -the one you see when you can type- then the problem is different. If this is the case post again and we can continue the search.
Sep 29, 2009 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
Wanting to be able to save what is typed in the form fields I mak
pdf is made not to be modified unless they have a pdf professional themselves. i recommend to use a web based application form.
Mar 02, 2009 | Adobe Acrobat 6.0 Professional for PC
Help with adobe 7.1.0
In order to edit a PDF document, you will need either one of Adobe's commercial Acrobat products or a similar third-party application.
You can often copy the contents of a PDF document to a word processor or text editor program (e.g., Microsoft Word or Notepad) and then edit them, but in this case you cannot resave the document as PDF (unless your word processor specifically has the ability to create PDF files).
To copy the document's contents:
from the Adobe Reader Edit menu,
choose Save as Text.
Alternatively, from the Edit menu, choose Select All; then, from the same menu, choose Copy, and then paste the text into your word processing program using that program's paste function.
May 07, 2008 | Adobe Acrobat 7.0 for PC
Adobe acrobat v7 can't open file
Do this:
1. Exit Acrobat.
2. Choose Start > Run, and type: %APPDATA%\Adobe\Acrobat\ into the Open text box. Click OK.
3. Right-click either the 6.0 or 7.0 folder, and choose Delete.
4. Start Acrobat and attempt to print.
Note:Acrobat preference files contain application settings such as toolbar arrangements. When you restart Acrobat, new preferences are created automatically based on application defaults. Deleting preference files will not result in the loss of saved documents.
Or, if u have having Quarkexpress in your machine update the version. Quarkexpress also creates PDF files, maybe this is where it was created from
Mar 14, 2008 | Adobe Acrobat 7.0 for PC
Adobe Acrobat 6.0 for PC Logo
169 people viewed this question
Top Adobe Computers & Internet Experts
Peter Dragonetti
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
