Question about Haier HDN655E Dehumidifier
What should i set my dehumidifier at - Haier HDN655E Dehumidifier
Frigidaire dehumidifier
Good Afteroon Friend, this is Z. Thank you for your inquiry!
Typically there are one or two reasons why your dehumidifier is not collecting water. Either the setting might be set too high or not enough moisture in the room. I suggest changing the set point to a lower setting. Ashumiditydrops in the room the amount of water will decrease and very little water may be generated even when in continuous mode. If these basictroubleshootingtips prove ineffective, then your dehumidifier may possibly have system issues. Is your dehumidifier still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Best!
Sep 05, 2014 | Frigidaire Dehumidifiers
Clean frigidaire dehumidifier cooling coil
Hello Friend, thank you for your post!
I see that you would like to know how to clean the coils on your Frigidaire dehumidifier and that it is no longer collecting water. The best way to clean the coils is by using a brush attachment from your vacuum. Typically there are one or two reasons why your dehumidifier is not collecting water. Either the setting might be set too high or not enough moisture in the room. I suggest changing the set point to a lower setting. As humidity drops in the room the amount of water will decrease and very little water may be generated even when in continuous mode. If these basic troubleshooting tips prove ineffective, then your dehumidifier may possibly have system issues. Is your dehumidifier still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Best - Z
Sep 02, 2014 | Frigidaire 50 Pint Capacity Dehumidifier
How to set timer on 2014 Kenmore 50 pt Dehumidifier
if you hold mode button down does it not cycle thru timer settings?
May 24, 2014 | Kenmore 30-Pint EnergyStar Dehumidifier
Whirlpool Gold dehumidifier #AD70GUSX pumps out tonnes of heat
You have to set the dehumidifier at 45 percent, above 45 percent will remove water from your body and will dehydrate you. Any dehumidifier it may be check how much percent you set it at. I have the same model ad70gusx I set it at 45 and I love it.. I am in a cool dry place
May 23, 2012 | Dehumidifiers
Recently bought a Frigidaire Dehumidifier four days ago. Ran it for 3 days on the co setting as the manual instructed. When I set the humidity level, after about 5 minutes it shuts down...does not come...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jan 21, 2011 | Frigidaire FDL25P1 Dehumidifier
HOW TO USE
follow the instructions below on how to use your dehumidifier:
Prepare the room for the dehumidifier by vacuuming, dusting and cleaning the room. Be especially careful to have all mold removed prior to using the dehumidifier.
Plug in the dehumidifier into a grounded outlet.
Set the dehumidifier to high in order to remove excess moisture from the room.
Wait for the dehumidifier to run several cycles, removing all undesired moisture from the air. This may take days or even weeks in especially damp rooms.
Adjust the setting of the dehumidifier when the air has reached your desired comfort level. Make the setting one that will maintain the current conditions.
Good luck.
Aug 16, 2010 | Woods WD25G Dehumidifier
What should I set it at
If there is actual water in the basement, any setting will probably cause the unit to run. I would suggest setting it around 60%, and turn it up as you feel necessary. Hope this helps
Apr 01, 2010 | DeLonghi DE500P Dehumidifier
I have a brand new Haier 45 pint Dehumidifier. The manual gives no advice on setting temperatures. What do I do? I set up with hose going in to my sump pump but no water seems to come out
Most of the time you set @55% RH. But on most Portable dehumidifiers you dont have a setting that tell you percent. Set about 1/2 way and see how much water it put out. That is about 60%. Go from there. Rus
Oct 29, 2009 | Haier 45-Pint Dehumidifier
Dehumidifier comes on runs for hours but does not dehumidify. The water pan is empty.
is there a setting ?? Dehumidify ??? as opposed to "Fan" if so set to Dehumidify...also turn up the dial to a higher number.....Is the element in the back Cold???? If on Dehumidify . turned up high and the element is cold...then you have a refrigerant leak and not worth fixing unless its under warranty
Oct 24, 2009 | Kenmore 54501 Dehumidifier
Haier HDN655E Dehumidifier Logo
Top Haier Dehumidifiers Experts
Shawn DuRee
Michael Vincent Cruz
Shehu Pro
Shehu Pro
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
