Question about LG LSC091PMA Split System Air Conditioner
Error code CH 23 - LG LSC091PMA Split System Air Conditioner
  • 90 Answers
There is a problem with a senzor on the outunit
Posted on Jan 13, 2014
My sharp ar-5520 error code CH please help me
There are 2 possible causes for CH code.
If CH is flashing on the display then the developer unit is not installed correctly.
If CH is static then the right hand side door is not closed or closing correctly.
Hope this helps.
Dave.
Sep 23, 2017 | Sharp Office Equipment & Supplies
How to fix LG error code CH 23?
There is a problem with a sensor ,but it must to change both(because are 2 senzor )even is broken just one.this senzors are locate in outside unit.
Nov 21, 2013 | LG LSC091PMA Split System Air Conditioner
How to fix LG error code ch 23
there is a problem with a sensor ,but it must to change both(because are 2 senzor )even is broken just one.this senzors are locate in outside unit.
Error code CH on sharp sf-2027
Hi olixrules
CH light blinking - The DV tank is not installed.
CH light steady - Door switch is not turned on (interlock switch is ON).
Source here.
Hope this gives you some idea, unfortunately I'm not sure how to resolve these error on this particular copier.
Scott
Feb 01, 2010 | Sharp AL-1642CS Copier
Ws-6580 error code 23
CODE / INDICATES
12 / No error has occured
21 / X-Ray Protect Shutdown
22 / Short Protect Shutdown
23 / Horizontal Deflection failure
24 / Vertical Deflection failure
Aug 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Mar 03, 2009 | Sharp AL-1641CS Laser Digital Copier
Sharp AR-160 has an error code CH when you power it on
Actually that means your out of ink. Odd code, but that is what is means.
Jan 29, 2009 | Sharp AR-160 Copier
Sharp Copier 2025 error steady CH
I believe that that error code relates to the dorter. Make sure it is seated correctly against the copier.
Jul 24, 2008 | Sharp SF 2020 Copier
LG LSC091PMA Split System Air Conditioner Logo
162 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
