Question about Gentron 10,000W Generator with Electric Start - Gentron
Outlets providing incorrect voltage
120v outlet is 240 twist lock outlet for house connection 1 side is 120 1 side is 240
    Problem Solver:
  • 20 Answers
The Wiring for this unit was screwed up in manufacturing. reverse the lines from the 120 side and the 120v end of the 240 pole. that should resolve the issue and you should also find that if you trace the wires back to the source on the dynamo they will now match/Pair up properly. Make sure to mark the wires you are swapping carefully and test under no load before load testing the unit.
Posted on Nov 21, 2013
Sunbeam heat pad says it requires 120V ac outlet. I plugged it into every outlet right out the box and have only gotten a red blinking light.
what voltage is recommended for the unit
It it says 120 volts but you have different voltage the it may be damaged from the incorrect voltage
if not the case take it back for a warranty exchange as it is faulty from go
Dec 28, 2015 | Sunbeam Heating & Cooling
Led wiring diagram on 240V AC
Is Led 120V or 240V?
For 120V you need a neutral wire.
240V generally does not have neutral wire.
http://waterheatertimer.org/How-to-wire-240-volt-outlets.html#120-240
Gene
Aug 14, 2014 | Hardware & Accessories
Can i change the plug socket over from 110v to 240v supply on my HR2470T-1/1
It would not be OSHA approved if in the US in an industrial location.
While not recomended practice, it can be done in the US to run off of 4 wire 240. You are just connecting to one half of the 240 outlet.
If you are in the UK or elsewhere with 240/250 volt mains- do not do this, use a voltage reducing transformer instead..
In the US, the standard is 120 /240 Or put another way- a 240 volt circuit in the home in the US, has 2 120 volt branches that share a common return, the 240 is derived across the 2 "120 sources"- hence your 2 pole breakers on 240 volt branches. If the socket is 3 terminal- which was old code- ground and the return were common at the outlet, it is a matter of just making sure the 240 volt plug terminals the 120 volt drill gets attached to is the ground/return (the one with the nib on it to make it index correctly in the outlet- (should be the wide blade lead or white and one black in the drill goes to either"hot" side of the plug- either one will work, and only one. On a 4 wire outlet, which is new code- the return goes to the white wire of the drill. And the black goes to either one of the hot sides. If drill has conductive case and grounding wire- that should connect to the outlet ground.
Mark on plug which two blades are used, so if you take it somewhere else, you can check (which should be standard operating procedure) with a meter to make sure their outlet is wired correctly.
Feb 11, 2012 | Drills
Why do i get power at the 120v outlet but nothing works when its plugged into the outlet
It sounds like a bad neutral wire. Somewhere the neutral is not properly connected. Most residential wiring operates on a 240 single phase system comprised of two seperate 120 volt legs. Connect between either leg to the neutral gives you 120 volts.connect btween the two legs gives you 240 volts. If the neutral is not present the circuit will search out the other leg to try to complete the circuit causing dimming of lights extremely bright lights and all around chaos. Check ahead of the main to see that the voltage is correct. Check each leg to neutral with a voltage tester. Have some one turn some lights on and off while checking as sometimes a load is required to get fluctuating readings. If the reading fluctuate wildly the problem is between the power grid and the panel. If not recheck on a a couple of breakers and if the readings fluctuate it is on your side of the system.
. Hope this helps
. Bob
Nov 21, 2011 | CUTLER HAMMER BR4040B200V BREAKER CIRCUIT...
Turned on for a second, shut off, wont come back on
Ouch! This is not looking good for for this A/C if you were somehow able to plug it into a 240 volt outlet. Very few of these appliances have fuses or other overvoltage / overcurrent protective devices built in.
Electrical outlets are designed to reject plug connected appliances that (1) draw more current (or amps) than the circuit can safely provide, and / or (2) those appliances that operate on a different voltage than available at the outlet. So, it would be pretty hard to get a 120 volt appliance to plug into a 240 volt outlet - UNLESS you have "modified" the plug's prongs. Tearing out ground pins and / or twisting blades with pliers definitely falls into the "modified" category. It can also happen if a "handyman" installs a 120 volt configured outlet on a 240 volt circuit and simply tells you it is 240 v, not 120 v.
The compressor motor is probably toast, as are any electronics used to control the unit. Nothing is unrepairable though - it just comes down to how much you are willing to spend on fixing a 3 year old unit - compared to the cost of brand new.
I hope this helps - and good luck!
Jun 07, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
On the outlets it has 4/120volts outlets and 1/120-240volts outlet. Can you use the 120/240 outlet as a reg 120volt? And what is the reason of the 120/240 outlet. Thank you
The reason for the 120/240 volt outlet is to be able to run things like large electric heaters or even your clothes dryer as they all require 240 volts. If you use it as 240 volts you will not have maximum current output on your other outlets so you wouldn't be able to plug anything really big in. And yes you can only use is as a 120V output if you would like but you will need a special attachment or extension cord. I'm going to leave you with two reference pages I looked up that you should have a look at.
http://www.powermate.com/generators/product_detail.php?model=PM0435003&cat_id=3&w=59
http://www.powermate.com/accessories/product_detail.php?cat_id=9&model=PA0650192
May 24, 2010 | Coleman Powermate Premium Plus 6250W...
How to wire a T101 240 volt timer switch?
Hello. a timer is just a fancy switch. since this is 240 volts, you have two 120 volt legs [one black wire and one red wire]. Begin with the white wires, just twist them all together and wire nut them. If there is a bare, do the same with them and connect them to the metal box and the device[if there is a green ground screw for this purpose]. Then, since you are switching the hot wires only, connect the red and the black hot wires to the top side of the timer and the pairs of reds and blacks to feed the outlets to the lower side of the timer.
Sep 18, 2009 | Hardware & Accessories
Will my Logitech X-230 speakers work in a country with 220-240 V power outlets or would i need an adapter to use them there? If i connect them directly to the 240 V outlet, will they run properly or would...
Check the back of your sub to check your voltage range. You will see something like this: 110V-120V or 110V-220V. If you see the later, you are ready to go. If you see 110-120V only, you will need a power converter to power your speakers as well as any other 110-120V equipment. But no matter what, if it is 110-120V DO NOT PLUG DIRECT TO 220V!! It will blow your speakers. (I lived in Germany for 11 years.)
Aug 12, 2009 | Logitech Z-2300 Computer Speakers
I am trying to connect my new pool motor. I have 3 wires coming out of the box. a black one 120v a white one 120v and a copper (ground). How do I test if it has 240v? How can I connect the motor so works....
Most probable cause is that you have the black and white on the same phase, and that's why you have 120 volts from black to ground and from white to ground, but 0 across black and white. If the motor ran on 120 volts, why are you connecting it to 240?
In any event, in order to get 240 volts, move the white to a circuit breaker that is directly above or below the breaker that feed the black wire. You are supposed to use a 2 pole breaker for 240 volts anyway
Jul 23, 2009 | Pool & Spa
Electrical wiring for 120/208 service as opposed to 120/240 service
Your machine requires 208-240 volts to operate with each leg being about 120 volts. Move refrigerators are 120 volts so even though you have 20 amps you probably only have 120 volts.
You can go to the Bunn website (bunnomatic.com) click on Commercial then on Publications then Illustrated Parts and Service manuals and download the manual for your machine that shows how the wiring hooks up in the machine and the type of cord the machine requires to handle the voltage.
The plug you need must match the receptacle in the wall and there are numerous 220volt plugs and receptacles on the market. Don't get a dryer plug instead try for a twist lock as they are more reliable.
Oct 21, 2008 | Bunn CDBCF 35 Coffee Maker
Gentron 10,000W Generator with Electric Start - Gentron Logo
83 people viewed this question
Top Gentron Electrical Supplies Experts
Phil Walker
Phil Walker
Adam Plug
Adam Plug
M.R.
M.R.
Level 1 Expert
Are you a Gentron Electrical Supply Expert? Answer questions, earn points and help others
