Question about iHome Wireless Optical Mouse
The red light flickers and goes out when i turn it on
The batteries are new - not sure what to do
My polaroid 300 camera wont turn on why?
Hi Sophie have u made sure there are fresh batteries in the camera and there is definitely film in there
Aug 14, 2014 | Polaroid 300 Instant Camera - Blue...
Why does my kinivo bth220 headphones have a flashing red light on them no matter how long i charge them and they will not turn on
The batteries won't charge. You might want to google around for replacement batteries.
First I'd try a factory reset. PRess the +, - and multifunction button for 6 seconds until the blue light flashes and it shuts off. When you turn them on next, it's in pairing mode and try again.
Aug 10, 2014 | Kinivo Bth220 Bluetooth Stereo Headphone -...
Blackberry Z30 does not turn on. Had it on charge red light flickering
Try getting a new battery because the battery maybe too old also replace the charger since sometimes chargers can become defective after a while.
Apr 15, 2014 | BlackBerry Z30
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
Brand new, never used. Plug into wall to charge and just get flashing red light. After 16 hrs on charge, still flashing red and when turn on, screen blinks then shuts down.
check that you have the battery in the correct way
if it has batteries like AA , AAA or what ever the negative terminal of the battery goes against the coil spring so if you have them all facing the same way, that may be why they are not charging
the screen shutting down at this stage would be cause the batteries are flat
of course you could always bet new fully charged rechargeable batteries and put them in correctly to see if the rest works
Apr 30, 2017 | Sylvania SDVD7015 7 in Portable DVD Player
My battery light and brake light goes on , some time goes off and on / I have a new battery and I change the altalnator
Check the battery terminals (where they are connected to the engine.) Those clamps can be loose or corroded. It happened to me and if i hit a bump or the road was bumpy, the battery cables would slide loose and the power would flicker or die completely
Open the hood when the car is off and try to wiggle the positive nad negative connections on your battery. They shouldn't move at all. If they're loose, tighten them up carefully. If they're covered in battery acid or corroded, then you may need new terminals for your new battery to connect well to your engine. Good luck, i hope this helps.
Mar 25, 2012 | Nissan Sentra Cars & Trucks
Solid red light
Have about a 30 second window to replace batteries before all codes are lost and when you put in the new batteries it goes into programing mode. Re-enter codes and try it again. Have the same remote and it has happened to me before.
Mar 12, 2010 | DISH Network IR Remote Control
Mouse unresponsive and red light flickering. you have to click the mouse to make it responsive again.. but if you leave it a little while the same procedure again
It sounds like the mouse goes on standby to conserve battery power, or the batteries are getting low. It's more likely it goes into a low power mode to extend battery life and conserve power.
Dec 19, 2009 | Logitech Cordless Click Optical Scroll...
Red keeps going out but there is a new bulb in place.
red light keeps blinking on and off but the tv isnt turning on
Jun 02, 2009 | Toshiba TN61X81 61" Rear Projection...
Car died, lights on dash flicker on and off as well as radio
Battery failed.Or alternator problem.Recharge the battery then try..If red light is sill on when car is running then the alternator needs replacing
May 28, 2009 | 2003 Saturn VUE
iHome Wireless Optical Mouse Logo
66 people viewed this question
Top iHome Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
indiana650
indiana650
Level 1 Expert
Tom Chichester
Are you an iHome Computer and Internet Expert? Answer questions, earn points and help others
