Question about Logitech QuickCam Communicate STX Personal Web Camera
Drivers does not install all wuapp32
If i instal the drivers windows does not want to allow all files to be instaled
  • Anonymous May 02, 2008
    WUApp32
  • 4,889 Answers
I suppose you are using windows vista..and having some compatibility issues.To get the latest drivers for your webcam click the link below click on GET SOFTWARE button under your webcam model then choose your OS and click on download software. http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405 Do this and let me know.. Kind regards, eagle
Posted on Oct 09, 2007
  • Logitech Master
  • 2,130 Answers
1st You download Webcam Driver.
Drivers
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Posted on Sep 16, 2013
We have Mustek Paragon 1200 SP flatbed scanner . We have driver for windows 98 . Now we need driver for Windows XP.
window 98 driver will work with windows xp. install the driver file right click and click install. using the setup file. or go to the windows devices. double click on the scanner in menu go to up date driver. in next box use the install driver from local file and make the file to the drivers you have it will install the files it needs. may say are you sure you want to install the driver as it has no certificate click yes., driver installed now.
Oct 05, 2013 | Mustek PARAGON 1200 SP Flatbed Scanner
Hp 1000 notebook wlan
Yes you will need driver / software for it, what wireless adapter you got?
Oct 04, 2008 | HP Pavilion dv1000 Notebook
Tip
Cannot install a device driver by using its installation program in Windows...
ISSUE- You cannot install a device driver by using its installation program in Windows Vista
OVERVIEW-
When you try to install a device driver by using its installation program in Windows Vista, you are unsuccessful.
SYMPTOMS:
You may experience this issue if the following conditions are true:
• The driver uses an executable file-based installation program.
• The installation program was not designed for Windows Vista.
CAUSES:
Problems with executable file-based installation programs may occur if any one or more of the following conditions are true:
• The installation program is incompatible with Windows Vista.
• The driver is incompatible with Windows Vista.
• An issue occurs that is related to the user rights that are required to install the driver.
RESOLUTION:
To resolve this problem, run the driver installation program in compatibility mode. Or, use an account that has administrative credentials to run the driver installation program. You can also locate the .inf file for the driver, and then manually install the driver.
Important Before you use one of these methods, we recommend that you contact the device manufacturer or the driver manufacturer for more information about how to install the driver in Windows Vista.
To run the driver installation program in compatibility mode
Configure the driver installation program to run in Microsoft Windows XP Service Pack 2 compatibility mode. To do this, follow these steps:
1. Locate the executable file for the driver installation program.
2. Right-click the file and then click Properties.
3. In the PackageName Properties dialog box, click the Compatibility tab.
4. Click to select the Run this program in compatibility mode for check box, click Windows XP (Service Pack 2) in the Run this program in compatibility mode for list, and then click OK.
5. Double-click the executable file to start the installation program.
To run the driver installation program by using administrative credentials
Configure the driver installation program to run in the context of the Administrator account. To do this, follow these steps:
2. Right-click the file, and then click Run as administrator.
If you are prompted for an administrator password or confirmation, type your password or click Continue.
3. Follow the steps to install the driver.
To locate the .inf file and manually install the driver
Use Device Manager to install the driver. To do this, follow these steps.
Step 1: Locate the .inf file
Locate the .inf file that is included with the driver installation program. Generally, the .inf file is located in one of the following folders on the driver installation media:
• In the same folder as the Setup program.
• In a subfolder that is in the folder that contains the Setup program. Generally, the subfolder has a name such as Windows XP, Drivers, or WinXP.
If the driver files are packaged in a single executable file, you may be able to extract them or otherwise access them. To do this, use one of the following methods, as appropriate for your situation:
• Use a file compression program to extract the files.
If the driver files are packaged in a single executable file, you may be able to use a file compression tool such as WinZip or WinRAR to extract the contents of the driver package to a folder. The .inf file should be among the files that you extract.
• Use the Windows Compressed Folders feature to extract the files.
If you do not have the WinZip program or the WinRAR program, you may be able to extract the files by using the Windows Compressed Folders feature. To do this, change the file name extension from .exe to .zip. Then, use Windows Explorer to copy the files from the compressed folder.
• Extract the contents from the .cab file.
If there is no .inf file in the driver package, but there are one or more .cab files, you may be able to extract the contents of the .cab files.
Note This method is usually unsuccessful. Typically, these kinds of driver packages are created by using the InstallShield program. The InstallShield program uses a special .cab format that is not designed to be accessed by tools such as WinZip or WinRAR.
• Locate the files in the Temp folder.
If you still cannot access the installation files, try to locate extracted temporary files. Typically, files are extracted to a local Temp folder when you install a program. You may be able to view the contents of the driver package by examining the contents of the Temp folder. To do this, follow these steps:
1. Remove the contents of the Temp folder. By removing the contents of the Temp folder, you can more easily locate the temporary files that are created when you run the driver installation program. To remove the contents of the Temp folder, follow these steps:
a. Click Start and then click Computer.
b. Right-click the hard disk on which Windows Vista is installed, and then click Properties.
 In the Local Disk (DriveLetter) Properties dialog box, click the General tab, and then click Disk Cleanup.
 In the Disk Cleanup Options dialog box, click Files from all users on this computer.
 Under Files to delete, click to clear all the check boxes, click to select the Temporary files check box, and then click OK.
 When you are prompted to permanently delete the files, click Delete Files.
c. Use Windows Explorer to open the Temp folder. To do this, click Start
type %temp% in the Start Search box, and then press ENTER.
d. Start the driver installation program.
Note Some installation programs automatically delete the temporary files when the installation program exits. Therefore, leave the driver installation program running in the background.
e. Examine the contents of the Temp folder to locate the driver files.
Step 2: Manually install the driver
After you locate the .inf file for the driver that you want to install, manually install the new driver. To do this, follow these steps:
1. Click Start , right-click Computer, and then click Properties.
2. In the Tasks pane, click Device Manager.
3. In Device Manager, locate the device for which you want to install the driver.
Note To display hidden devices, click Show hidden devices on the View menu.
4. Right-click the device and then click Update Driver Software.
5. Click Browse my computer for driver software, click Let me pick from a list of device drivers on my computer, and then click Have Disk.
6. In the Install from Disk dialog box, click Browse, locate an .inf file for the device driver that you want to install, and then click Open.
7. Follow the steps in the Update Driver Software DeviceName dialog box to update the driver.
on May 10, 2010 | Computers & Internet
Tip
Installing canon mutipass F80 on windows xp
If you are having problem installing canon multipass F80 on windows xp, you are not alone. This is the process:
Power on the printer
Connect the US cable to the computer
Allow windows xp to find new hardware
choose the option that allows you to locate the driver
Point your computer to the location of the downloaded driver
choose windows2000xp
then allow windows to install the driver
After windows has finishing installing the driver, run set up again from the file you downloaded. You will be ok and ready to print.
on Mar 23, 2008 | Canon MultiPASS F80 All-In-One InkJet...
I want motherboard drivers for compaq KT477AA ACJ SG3430IL drivers (windows 7 32 bit ) Pls help me..
Windows 7 can be told to use the Vista drivers for most things.....did you try that ?
[ Note : This method should only be used whenever you have a "setup file" or .exe extension to run to install the drivers.]
Leave the device unplugged while doing this (Unless the drivers are stored on the device, for instance a Mobile Phone)
If you have already installed the Incorrect Drivers, then do a System Restore, or Restore a System Image, to a point before you installed the drivers, otherwise this might not work.
1. Right-click the Setup File and choose -Properties-.
2. Next, click on the -Compatibility- tab.
3. Then, check the box marked "Run this program in compatibility mode for" and select -Windows Vista- from the drop-down list.
4. Next, check the box "Run as Administrator", then press the [OK] button.
5. Run the setup file as normal, and should allow the installation of the Vista driver files.
Tallon41
Sep 11, 2012 | Compaq Computers & Internet
Need software for web camera. I updated windows from vista home to win 7 home 32 bit
HI
Install the same installation file for your web cam in xp or vista
in windows 7 too...
its a trick
in which we are installing this driver in windows 7
compatibility mode allows any file on previous versions of windows to be installed in windows 7
For that
>>right click on the file
select properties
check the compatiblity tab
select windows vista
and dont forget to check"Run as administrator"
and apply
Hope this will solve your problem
Mar 02, 2010 | Sony VAIO VGN-NS140E/S Notebook PC
My laptop has sound problem
The Problem:
After you install Windows on a computer, you then need to install the "drivers" for your computer. A driver is basiclly software that allows your hardware (such as your sound card) and your Operating System (Windows XP) to communicate. Since you have not installed the audio drivers yet, you don't have any sound.
The fix:
Simply download and run this file: http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_audio_realtek_25392E.exe
That will get your sound back!
Dec 02, 2008 | Toshiba Satellite A135-S2276 Notebook
C2110 modem drivers for vista
I INASTAAL MYMODEM , CONNECT TO COMPUTER ANDMAKE NECESSARY SETUP BUT I CANNOT CONNECT TO REMOT COMPUTER IT SHOWS PROLEM 618 . PLZS .GIVE SOLUTION
Jan 26, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
How to install driver
How do I install a computer driver?
Answer: Microsoft Windows users Depending on how the driver has been packaged is what determines how the driver will be installed. Below is additional information about each of the methods developers use to distribute their drivers and how you would install the drivers in Microsoft Windows.
General driver tips
Below are some general insights to help prevent any additional frustration that may be encountered while installing drivers.
Drivers on CD or floppy diskettes:
Almost all computer and hardware manufacturers include a group of drivers for different hardware devices and often for each of the supported versions of Windows. For example, the driver CD you receive with your printer likely contains the drivers for dozens of different printers. Not just the printer you purchased, which means when installing the drivers make sure you're installing the drivers for your printer, not another printer model and that you're installing it for the version of Windows you're running on your computer.
Below is an example of how a file structure may look on your disk.
CD Example:
-PrinterA100
--Win9x
--Win2k
--WinXP
-PrinterA200
--Win9x
--Win2k
--WinXP
-PrinterB100
--Win9x
--Win2k
--WinXP
If for example you had a PrinterA200 and were using Windows XP you would find your drivers in the PrinterA200\WinXP directory.
Downloading drivers:
Almost all drivers you download are going to be a single file if the file is not an executable file it is almost definitely a compressed file that contains all the driver files. In order to install the driver you will first need to uncompress the file. Additional information about how to uncompress a compressed file can be found on document CH000506.
When extracting / uncompressing the drivers make sure to remember where you place the folder containing the drivers as you will need to point Windows to this folder when installing the drivers. We usually recommend users install the driver files in a folder on their desktop as it's an easy place to remember and locate.
Finally, the single file and/or the files extracted from the compressed file can be deleted after you have finished installing the drivers.
Executable
Many computer and hardware manufacturers today are pre-packaging their drivers into executable files or have the drivers installed through the setup file, which means simply double-clicking the setup file or the file you download should install the drivers to the computer for you.
Note: Many developers may package their drivers in a compressed file, which means before looking for the setup file you may need to uncompress the downloaded file. Information about doing this was explained above. If after uncompressing the file it still does not contain an executable file, some type of setup file, or does not install your hardware device continue with the below recommendations.
Finally, if you were successful in installing your drivers make sure to reboot the computer after the drivers have been installed.
Using the have disk option
Often computer manufacturers and hardware manufacturers will also simply place the drivers on the CD, diskette, or download for Windows to find and use during its hardware detection. Below are steps on how to install drivers for a new device and upgrade a devices driver for this type of setup.
Installing a new device
Upgrading drivers for pre-existing device
  1. Open Windows Device Manager. Information about how to do this can be found on document CH000833. In the Device Manager make sure the device you're attempting to install is not already listed from past install attempts. If the device is found highlight it and remove it from Device Manager to prevent any conflicts during the install.
  2. Once Device Manager looks ok reboot the computer.
  3. As the computer is rebooting an install new hardware wizard should appear if Windows detects the new hardware using this wizard you should be able to point Windows to the folder containing your drivers either on the CD, diskette, or the folder containing the files you downloaded.
If Windows does not detect any new hardware open Control Panel and double-click the Add hardware icon to run the hardware detection wizard. During the steps you will have an option to tell Windows you have a disk containing the drivers for your new hardware device, at this point point Windows to the directory containing the drivers for your device.
Once drivers have been installed reboot.
  1. Open Windows Device Manager. Information about how to do this can be found on document CH000833. In the Device Manager locate the device you wish to update the drivers for.
  2. Right-click the device and click Properties.
  3. In the Properties window click the Driver tab.
  4. Click the Update Driver button.
  5. In the Hardware Update Wizard point Windows to the location of the updated drivers on your hard disk drive
Install through the .inf file
Finally, if the above recommendations do not work the installation instructions for drivers and hardware devices are always contained in a .inf file that is located within the drivers.
Locate the .inf for your version of Windows right-click that file and choose the option for install. Note this is a very raw form of installing a drivers and it is important that you make sure you're installing the correct .inf file and not a .inf file for another device or for a different version of Windows. Additional information and tips about locating the drivers was explained earlier in the general driver tips section.
Once you have right-clicked and installed the driver reboot the computer
One of the above three recommendations should have installed / updated the drivers successfully onto the computer. If you're still having difficulties getting the device to install it's possible you're not encountering a hardware issue and not an issue with the drivers. Refer to the troubleshooting steps for your hardware device for additional help and information.
Dont for get to Vote
Merry Christmas....Good Luck!
Dec 06, 2007 | ASUS P4XP-X Motherboard
Where can I donwload the Micro3 business card scaner driver?
I have the original drivers disk.! Send me an email: SO i can respond you are still interested. MyPepsiBottleCaps@yahoo.com
Dec 17, 2006 | E-Book Systems, Inc. Micro 3 Business Card...
Logitech QuickCam Communicate STX Personal Web Camera Logo
586 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
