Question about Primera Technology LX400 Color Label Printer (P/N 74261)
Won't print even though label feeding
When I click 'Print' the Primera LX400 starts to spool as if going to print and then stops...giving a non-descript error message...can you help please? Thanks
5 Suggested Answers
edisonfrelan
  • 113 Answers
SOURCE: Primera Bravo CD/DVD printer -- prints blank
Let the printer repair itself. Got to start menu select the printer then select properties. Go to maintenance menu try all the basic testing. If it still didn't work out, delete the previous driver and install it again, then restart and try printing again.
Posted on Dec 14, 2008
SOURCE: My LX400 was printing correctly
First, the fuser assembly may be damaged or at the end of its life. The solution is to replace the fuser assembly. Repairing a fuser assembly is generally not recommended because the fuser is considered a consumable printer part and not worth the time or effort to fix. Second, the toner cartridge may be defective and letting too much toner out at one time. in this case, you will need to replace it.
Take care.
Posted on Aug 22, 2010
mariolands
  • 2296 Answers
SOURCE: I installed a new ink cartridge in my Primera
Have a look in the User Manual for this model: http://www.primera.com/pdfnew/510984_link.pdf
Also, have a look here for Troubleshooting with this printer http://www.primera.com/knowledgebase.html
Posted on Nov 19, 2010
muntejaya
  • 10421 Answers
SOURCE: i have primera lx810 label printer, it will not
Please get the correct driver here : www.printcountry.com/drivers.asp
www.opendrivers.com/.../printers-free-driver-download.html
www.driversdown.com/driverslist/r_4_1.shtml
Regards, Jay__897dtg4e
Posted on Feb 26, 2011
HP psc 1100/1200 all-in-one stopped printing
Press and hold the cancel button and then press the start copy button release them together.
You should print a test page. No Test page an internal printer problem is likely!
If test page is good reset the spooler \. More than one way to reset spool file. Spool file controls transfer from computer to printer. Spool file a mess then printer hangs!!!
Method 1
a. Go to Start / Control Panel / Administrative Tools / Services
b. Select "Print Spooler".
c. While Print spooler is stopped, start it by double-clicking on "Print Spooler" and then click the "Start" button.
d. Verify that the "startup type" is set to "automatic".
Method 2
Create a new txt file
Type in exactly as the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Rename txt file killspool.bat
save on desk top
Double click off of desktop file to run
Next time printer hangs you can use this file again
Hope this helps?
Dec 03, 2016 | HP Office Equipment & Supplies
It kep saying that the spooling is not working
It could be that the Print Spooler service has stopped and won't let you print. Please follow the steps below to fix the problem:
1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Try to print again.
Jul 25, 2011 | Lexmark X2600 InkJet Printer
Spooling subsystem error. I can print some things but some things get stuck and I cannot even delete them.
Click "start" and go to "Run"
Type "services.msc" at the prompt which will open the Services
window.
Scroll down the alphabetical list in the right window pane until you come
to the entry with the name "Print Spooler"
Right-click this entry, then select "stop". This will stop the computer
running the process that holds your print queues.
Leaving that window open for now, click again on "Start", and then click
"My Computer" to open a Windows Explorer window.
We've stopped the queue service, now we just have to clear the jam that is already there. To do this we navigate to the print spool folder which is hiding within the Windows folders. Usually Windows is installed on C: drive, but you should be able to tell when the Explorer window opens which drive it is on.
The usual path to the spool folder is C:\WINDOWS\system32\spool\PRINTERS, but yours may be slightly different. Your windows drive may have another name for instance, but this would be uncommon. So click on your Windows drive (usually C), then double-click on the Windows folder, and then find the System32 folder and double-click on that. Windows may warn you that you are about to view system files, but click "View files anyway" message and search out the "spool folder". Within the Spool folder is your Printers folder, and you should open that.
Delete every file within this folder to empty the jammed print queue (pressing the "ctrl" and "a" keys will select all files and then you can just hit "delete").
Close the explorer window now that we have emptied the cleared spool files and return to your Services window. We must re-start the Printer spooler service, and do so by right-clicking the Print Spooler entry and selecting "Start" from the list. Close the services window and try printing again.
Mar 25, 2011 | Computers & Internet
My Dymo Labelwriter 450 turbo feeds out 4 labels each time I print one. The print setting is on one label. The first one prints and the next three are blank. If I try to use the reverse button the printer...
Multiple label feeding usually occurs because the sides of the spool holding the roll are not squeezed tightly together. Make sure there's no gap between the labels and the sides of the spool. If this doesn't help. take out the labels and blow a blast of air into the feed slot. There is a sensor inside the slot on the left that detects the hole in the labels, and maybe it is blocked.
Jan 26, 2011 | Dymo LabelWriter 400 Thermal Printer
Printer only prints one page of multiple page document
hi..
You may try to change the spool data format:
1. Click on "Start," "Control Panel," "Printers and Other Hardware" and "Printers and Faxes."
("Start," "Control Panel," "Hardware and Sound" and "Printers" for Vista...)
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark *** series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Try printing again.
Apr 24, 2009 | Lexmark P4350 All-In-One InkJet Printer
Advances ticket too far after printing.
your label length is set incorrectly, there are 2 things it could be
1) your software is telling the printer the label length is longer then the current labels, even if the label size is out my a single millimeter the printer will give you this issue of feed an extra label. you need to change this in your software. you can set a label size smaller then the current label size and it will work correctly
2) you software is not setting a label length and so the printer is going off its internal setting, to recalibrate hold feed and power up the printer letting go after the light starts flashing
it is important to note that label roll will change slightly over time so even though you are ordering the same labels as a year ago the manufacturer will have slight changes from batch to batch
Nov 05, 2007 | Zebra Eltron TLP 2742 Thermal Label...
2 LABELS COME OUT
Oct 13, 2007 | Zebra LP 2844 Thermal Printer
AS400 Spool files stuck in outq in send mode
I have WiFi Zebra QL420. In my case a simple header label prints fine then the complex label (many fields, barcode, lines & boxes) gets stuck. Labels are in separate spol files. We have many other labels printing fine, just this one ALWAYS gets stuck.
If I send same data from PC to printer it works fine.
I can see with ethernet sniffer that header label data goes but complex label doesn't even leave the iSeries. My sniffer is too crude to tell me what LPR level protocol is saying.
Oct 10, 2007 | Printronix T5000 Thermal Printer
Cannot delete print job
click settings-control panel-administrative tools-services-select 'print spool' from the list-in dialog box click stop-and again click on start. Hope this solves your problem.
Jan 17, 2007 | HP PSC 1315 All-In-One InkJet Printer
Primera Technology LX400 Color Label Printer (P/N 74261) Logo
43 people viewed this question
Top Primera Technology Office Equipment & Supplies Experts
Josh Whitehead
Josh Whitehead
Guy Loeffler
Guy Loeffler
Level 1 Expert
Martyn01202
Martyn01202
Are you a Primera Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
