Question about Abit KV7-V Motherboard
KV7-V power supply
I think my power supply has fried. The computer was on and suddenly shut down. I let it set for awhile and it started back up but shut down after about 30min withan electical burn smell. I want to replace it but am confused. The old one is a POWMAX, ATX Switching Power Source @ 400watts. What would be a good replacement and maybe with a little more power?
Thanks sandrew.  The power connection was fine.  I ordered a new power supply 500w and have just finished installing it.  And it is running fine.
Posted on Oct 12, 2007
  • 2,961 Answers
Follow the power cable from the PSU to the motherboard and see if the 21 connection has melted to the motherboard. You are better getting a 500W silent type, but it depends on the peripherals you have installed, try for various makes.
Posted on Oct 09, 2007
My computer won't start, it appears to have no power. For the past 2 weeks when ever I would start up it up I would have to constantly push the start button 3 to 5 times till it would power up. Now it...
Most likley you have a fried power supply. Try this first unplug the computer from the power cord for 5 minutes then plug back in and go into safe mode see how to go into safe mode below.
To start the computer in safe mode 1.
You should print these instructions before continuing. They will not be available after you shut your computer down in step 2.
Click Start and then click Shut Down.
In the drop-down list of the Shut Down Windows dialog box, click Restart, and then click OK.
As your computer restarts but before Windows launches, press F8.
On a computer that is configured for booting to multiple operating systems, you can press F8 when the boot menu appears.
Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
Chris Thrash
Please Vote
Jan 10, 2011 | Gateway GT5014 PC Desktop
After pc is on for awhile the power light blinks amber and I have to power off then power on.
It sounds as though your computers hibernation feature is malfunctioning, or your power setting are set to shut your computer off. If I were you I would attempt to disable both features, Go to Start in the bottom left, click on Control Panel in the Start menu, and then go to Power Options. Basically just tell it to never shut off any hard disks or the computer.
Dec 11, 2010 | Dell OptiPlex GX520 PC Desktop
I was running a virus check, asked what to do, I said fix, computer shut down and alarm buzzer came on. now I don't get a boot sound
With the system shut down, unplug the power cable from the power supply. Open you're case and pull the memory from the system wait a minute than reseat the memory. Re-connect the power cable to the power supply. Try booting the system and enter the bios menu. (Pulling the memory will clear any memory resident virus). This has nothing to do with the alarm buzzer sound you heard. Typically the alarm sound is generated by the CPU. It's an audible warning that the CPU is over-heating. The CPU will shut down you're system so as not to damage the motherboard and CPU. (Suggest you check the CPU fan for dust build-up. Use canned air to help remove any build-up. You can also use a clean paint brush to help remove any dust from under each CPU fan blade.
It's also possible that the CPU fan is running far too slow and may need to be replaced.
See page 3-23 in you're user manual.
3-8. PC Health Status.
Open the link provided below for a new heat-sink and fan assembly for a socket 462;
If the CPU fan and heat-sink assembly seems clean it is also possible that the thermal grease / thermal tape between the heat-sink and CPU is too old and needs to be replaced. (Save this check for last).
Below is the link for you're motherboard;
Feb 20, 2010 | Abit KV7-V Motherboard
My computer starts to load windows, then loses all power,
Does the same thing happen when you try to load the BIOS. (press keep pressing F2 when you turn on the computer). If it happens while the computer is in the BIOS window then its your power supply that is fried.
It does sound like the power supply is fried though. In which case the laptop will need to be taken in for service.
Oct 03, 2009 | Toshiba Satellite P100 Notebook
PC Shuts down suddenly without warning
As u would 1st know that there is a perfect power supply of 220-230V,
& if Yes try replacing the SMPS, If you still hve the same prob thn its, Motherboard problem, As i am a technical person & Faced many problems like these.......
Mar 12, 2009 | Computers & Internet
PC Shuts Off with No Warning!
Hyperthreading is not active in a dual core system. It is a software phantom core that is used for single core processors that support hyperthreading, eg Pentium IV 3ghz and above.
I think your problem lies in the power settings that you have selected. This problem appears when incompatible hardware is present on the system and you have allowed the system to go into standby and/or hibernate mode. Pull up your power settings in the control panel and make sure that no standby or hibernate options are selected. See if that helps.
Feb 18, 2009 | Computers & Internet
Desktop won't start after Hurrican IKE power outage
the only thing i can think of is the power supply got fried that is the most common problem when it comes to the pc not powering on. Now hopefully that is all that it fried and not the motherboard my suggestion is to take to local pc repair shop and have them change your power supply or you could put it in if you familiar with how the machine is wired.
Sep 14, 2008 | HP Pavilion a800n (PP163AA) PC Desktop
Dell Latitude Problems
Liquid, pee in your case, no matter how small, can cause an electrical short and fry motherboard components. I'm going to say that it has fried a component, and you'll want to have it checked out. Since the unit does start on occasion, then it's most likely going to be a replaceable component, probably the power switch circuit.
Aug 04, 2008 | Dell Latitude D600 Notebook
GA-EP35-DS3R won't POST - Core Duo E8400 / 2GB Crucial 8500 DDR2
remove your cpu core voltage connector and power on if power on still so 100% your vrm circuit mosfet sort
Mar 30, 2008 | Intel Motherboard
Power On trouble with Computer
If don't you have any beeps check maybe the power button stack.
If the power button pressed for four seconds then the computer normaly shut down.
Jan 11, 2008 | Abit KV7-V Motherboard
Abit KV7-V Motherboard Logo
98 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
