Question about GE Refrigerators
Ge gsl25jfrfbs water not working - GE Refrigerators
3 Suggested Answers
rpbuice
  • 161 Answers
SOURCE: ge gsl25jfrfbs water disoenser not working
Solenoid or the dispenser switch.
The water supply line connects to a water valve on the Ref. this water valve has two solenoids, one for the ice maker and one for the water in the door. Check this solenoid with an OHM meter.
The dispenser switch should send 110 volts to the solenoid. Check at the solenoid while pushing the water switch in the door.
Posted on Jan 19, 2009
aasc
  • 1606 Answers
SOURCE: Water stopped coming out of the front
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
There is also a dispensor heater , you may want to install , pt # WR49X10173 . This should keep the water line from freezing again , if it turns out to be that problem .
Posted on Nov 07, 2009
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Keep getting a f9 and f10 code . how do we fix what do they mean
1) F9 and F10 appear to be element failure/ Call for service
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#element
2) Copy following link for more GE Hybrid Geospring resources:
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
3) Call GE and they will tell you to call for service:
1-888-443-4394
4) 2009 service manual says you can clear fault codes by pressing Filter, Lock, Vacation button sequentially within 3 seconds. Scroll to clear all fault codes using arrow keys. When that is highlighted, press Filter, Lock, Vacation again.
Others report this does not work, so it may depend on model. Or maybe buttons need to be pressed simultaneously.
5) GE does not want folks working on their own water heater.
Do not buy expensive water heaters you cannot fix yourself.
Average service call for GE heat pump is $400 which helps defeat anticipated savings from buying hybrid.
Jan 26, 2013 | General Electric GE GeoSpring Hybrid Water...
My ice maker is working fine. My ice dispenser is working fine, There is no water from the water dispenser. When I push the button, I hear a click but no water.
I had this same issue with my GE refrigerator and figured out it is a common problem with these units. The water line freezes up near the dispenser panel. Fortunately, GE has an inexpensive solution, a water line heater, that fixes the problem with little work. Check out my blog post on my ge refrigerator water dispenser not working for complete details.
Oct 28, 2010 | GE GSH25JFR Side by Side Refrigerator
Nov 07, 2009 | GE GSL25JFR Brushed Steel Side by Side...
GE ice maker work's but no water coming out, when i put the glass for water hear no contact.
i've been having a lot of problems with the GE's water lines freezing inside the door. I installed the "fix" and it lasted 6 mos. if u want to check..leave the door open for a few hours and check it again.you may just have to live with it.sorry
Jun 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge gsl25jfrfbs water disoenser not working
Jan 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Fridge intermittent
I had the exact problem with my GSL25JFRFBS. It turned out to be a bad control board. The service technician that replaced the board said that the lights dimming on the on the ice/water dispenser is a direct indication of the control board being bad. This cost me $303.53 and my refridgerator is only a little over 2 years old. You can buy a new control board - WR55X10656 from GE online for a little over $157.00. From what I've found, this is an inherit issue with this model.
Oct 30, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
12 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
