Installed in 5/07, ran fine for 3 months, then it would not start - no lights, nothing. Reset breaker and it ran fine, cold air. Then it quit. Now sometimes it runs, sometimes it is dead. Replaced batteries in control. No luck. Once when it would not start, I checked voltage = 115.9, also has voltage on the protection line. How do you determine if it is the remote or one of the two circuit boards? Any suggestions would be helpful.
-   Hi, i dont understand the remote control. i changed the battery, but cant seem to get the right settings for the air conditioner to cool right. its a SANYO SAP. Please Help!
-   Guest
Nov 11, 2007
-   Unit ran well for about 2 months then it just stopped. I checked the voltage going into the inside unit whick was ok. I changed batteries in the remote, still no go. About 1 week after giving up on starting the unit, it starts up. I did nothing during the 1 week. It now runs for 2 or 3 days then just stops (with me doing nothing). You go figure. The dealer is sending me a new circuit board.-   smokinhotime
Check your remote control the timer may be activated. Or try to push the reset button on your remote control to set it to default setting or just pull out the battery then insert it again then try. If problem persist then qualified technician is needed.
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a...
(More)
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a forced air system. Recommendations from heating contractors include Trane, SlantFin and Weil-McLain. Are these the best choices?
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at...
(More)
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at the lowest price. We stand by and guarantee the quality of our laptop battery.
<a href=http://www.bestlaptopbattery.co.uk/hp/dv1000.htm>Hp dv1000 battery</a>
Our Price: At Bestlaptopbattery.co.uk, you always pay the lowest price. We make this sure by offering our Best Price Guarantee on all our Hp dv1000 laptop battery.
Our Service: We have a dedicated team of customer service executives who are eager to help you save time and money by sharing their knowledge and expertise on batteries and related products.
Your Satisfaction: Your absolute satisfaction is our top objective. We stand by the quality of our battery and offer a 30-day money-back guarantee on all our products, no questions asked. Our products also carry a 12-month full repair or replacement warranty for any form of manufacturing defects.
How can you care Hp dv1000 laptop battery to get the maximum life out of it?
It is a question we frequently asked. It's a valid question since laptop batteries are usually expensive to replace.
First of all, how long should your battery last? 2-4 years is generally acceptable depending on how frequently you use and charge the battery. If you travel a lot and use and charge your battery frequently then you might only get a couple of years at the most out of your laptop battery.
The Hp dv1000 laptop battery are usually made with Li-Ion laptop batteries and the very nature of Li-Ion batteries is that they have about 500-600 charges and last at most about 4-5 years (shelf life). They also have a self-discharge rate of about 1% per day so you need to be sure to charge them at least every 6 months.
Hi, I have WeatherKing furnace and is not igniting the spark when the blower is on. I called...
(More)
Hi, I have WeatherKing furnace and is not igniting the spark when the blower is on. I called technician and he said we have to change pressure switch Model number : 80PJ10ECR01. Can I do it myself and what is the procedure to change the pressure switch and how much is the cost of the above model.
i cannot get water to flow into my mesh. The unit is an Autoflo A40 and is 22 years old. I would...
(More)
i cannot get water to flow into my mesh. The unit is an Autoflo A40 and is 22 years old. I would like to replace it with another, or a similar unit that would fit into my furnace plenum.
Can you help me?
Hi, I have a mistral split system air conditioner that no longer runs. My young son got hold of the...
(More)
Hi, I have a mistral split system air conditioner that no longer runs. My young son got hold of the controls and I think he's upset the programming operations. It starts momentarily, then brings up the F6 indicator, where it would normally display the temperature position. Nothing exists in the instruction manual and I have gone online, finding that other's have suffered the same fate. Can you please help me!
