Question about Canon NP 6035 Copier
Copier failure ON SWITCHING ON,IT DISPLAYS E244,THEN SWITCHES OFF
  • 64 Answers
An E244 error relates to a communication error between two or more PCB's. Its most likely that your DC controler oard has gone and will need replacing not sure what they currently retail at sorry Hope this helps Cops Pete@wedotoners.com
Posted on Oct 10, 2007
Unload output tray
The Tray Full indicator lights on the appropriate stacker tray
(applies to dual stacker only).
A message displays on the printer control console that
indicates which output tray is full.
In automatic switching mode, the system automatically
switches over to the second tray (if it is empty) when one
tray is full (applies to the dual stacker only).
If only one tray was selected or if both output trays are full,
the printer stops.
The picture on the graphic display shows the location of the
full tray.
Still having Problem Then follow Us For
Brother Printer Support
Feb 11, 2014 | Brother HL 2700CN Laser Printer
How can i solve this E244 error code
A E244 error code deals with the scaner. When you turn the copier ON will the scanning lamp turn ON? If it dose and you make a copy and thhe scaner moves & start to make a copy and then codes out. The problem is the BLACK scaner power cable has a crack in the coatting and is arching out to the frame o the copier..... It is not a easy fix.... If the scaner lamp is not turning ON???? You may have a blown Lamp or thermal fuse.... You can still find these parts..... The code will not go away till the problem is fixed.. Good Luck
Oct 21, 2011 | Canon NP 6035 Copier
It displays l6
L6 = Polygon Motor Lock Detection
The Polygon Motor spins the mirror which writes the laser signal to the drum.
If switching the machine off/on doesn't cure the error code the only other thing you can do iw just check that all the connectors are plugged in correctly. Polygon Motors do fail and when they do all you can do is replace them. Quite often they will screech or rattle in the run up to failure.
Hope this helps.
Feb 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
Repeated IOGear KVM switch failures
As a wild guess, it sounds like a static discharge MIGHT be affecting the switcher causing it to crash.
Try increasing your humidity to 40% and grounding yourself before touching the keyboard... This is the season for these static electricity problems... get nipped all the time and you MAY not even feel it to be enough to zap the switch.
Jan 11, 2010 | IOGear MiniView GCS62 2-port KVM Switch
My system is switching on.. displays the screen of motherboard and switches off.... i have tried it many times it is happening again and again
try loading the computer in safe mode.. you might have gotten hit with a trojan that will constantly restart your comptuer(it changed your Autoexec.bat.
What OS are you using?
May 21, 2009 | Eizo FlexScan T 566 17" CRT Monitor
Canon NP 6230 copier - what does error code e244 refer to?
you have a scanner or lens problem look in the glass when you turn it on both the scanner and the lens should move some
Jan 13, 2009 | Canon NP 6230 Copier
Our TV screen no longer displays pictures, it just displays a blue screen and sound. The inbuilt DVD player still works with pictures and sound. Whay can I do to fix this?
Without the make and model number, I can no tgive you specifics. In general there are switches that control the source of video and audio signals internal to the set. If the switching chip for the video section is defective, this can occur. Post the make and model and I'll try to provide more details.
Thanks,
Dan
Apr 17, 2008 | Televison & Video
Switching
The switching software that you installed on your computer when you installed the KVM includes an optional setting called "scan" that can be set to automatically page between the two displays.
This is most often used when the device is used for network or server status monitoring. If you configured that to switch every one second I can see how that would be very annoying.
Check the configuration of the switching software to verify that the scan setting is turned off.
Nov 13, 2007 | Belkin F1DK102U 2-port KVM Switch
Canon NP 6035 Copier Logo
138 people viewed this question
Clive
Clive
old marine
old marine
