Question about Dirt Devil M1100009 Reaction Soft Touch Cyclonic Upright Vacuum Cleaner Vacuum
Brush on/off lever
I went to replace my broken belt and a "U" shaped gold piece of metal fell out. Now my on/off lever for my brush seems to be backwards. If I put the lever in the off possition the belt gets tight and spins the brush and in the on possition it is off. The problem is that in the off possition I can smell the belt getting hot and see it breaking away. Any suggestions?
Replacing a belt or how to get into the vacuum cleaner . It is a Dirt devil Reaction D2
Posted on Feb 23, 2008
How do i replace the belt on my hover
lower handle to floor and flip entire unit over. In the bottom near the brush, there are 2 levers that hold the cover on. flip both levers and pull up on cover. It will come out of the 2 wire holders that hold down the 2 front tabs.With the cover removed you can easily access the brush. Firmly grasp 1 side of the brush and pull straight up. This may take a lot of force as the brush may have been seated for a long time. Pull both sides out and clean the area underneath the brush. Also make sure nothing is wrapped around the brush or motor.
After cleaning you're ready to install new belt. Place new belt around brush. After pushing brush through the new belt, with belt loosely around brush slide brush back into housing 1 side at a time. The brush fits in very tightly. The ends have 2 pieces of metal that act as springs, these are installed facing the top. Make sure the brush is pushed down tightly toward the bottom or the cover will not fit right. Once brush is in stretch belt around motor tip. Replace cover by placing the 2 tips into the wire clips and close. Flip the latches closed and turn machine over. Lift handle and you're good to go. You have now completed the worlds longest instructions for a vacuum belt...ever!
Jun 11, 2012 | Vacuums
NEED TO CHANGE A BELT
First you need to remove the metal cover to expose the brush roll assembly. Push up the plastic cover connected to the foot pedal to expose the motor shaft. Remove the brush roll assembly and simply hook the belt on the motor shaft first then pull back the brush roll and push the brush roll back to the slot. There's a small piece of plastic on the left hand side of the brush roll. This piece would go in after the brush is set in the slot. Finally, replace the metal cover.
Jun 23, 2010 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
I have the bissell power force bagged upright vacuum and the brush is not turning, I have replaced the belt but the brush will not move but the metal piece that is hooked to the motor that spins the belt...
sounds like your brush roll is seized. Remove the brush roll (see picture) and make both of the end caps spin freely. If not, replace it and you should be set.
*An example of a brush roll*
Make sure that the brush roll spins freely.
Hope that helps.
Chris
Jun 09, 2010 | Bissell 3522 PowerForce Bagged Upright...
We have power but the front brush does not turn?
Your belt is probably broken, stretched or worn. You can get a replacement belt here:
Bissell Healthy Home Replacement Belt
Nov 25, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Nov 25, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Dirt Devil overheating Belt Okay
the belt is probably worn , so when the spool turns it heats up and looses friction with the belt.
Jul 05, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Brush froze up and keeps breaking belts
I had the same problem but I found that I had replaced belt incorrectly. After placing one end of belt around pully, it has to be run behind the "belt disengager" which looks like a 1/2" wide metal tab just past pulley. After placing belt correctly I had no more belt, burning smell or brush problems.
Feb 25, 2009 | Bissell Upright Vacuum - The Pet Hair...
Belt keeps snapping
Check your brush. It is likely that the brush is broken and will not spin. Hold the brush by the end caps and spin the brush and if it will not spin freely that is your issue.
Oct 31, 2008 | Bissell 3576 CleanView II Bagless Upright...
Replacing Belt
On the front of the power head is a knob with the KIRBY name on it. Rotate this knob in a counter clockwise direction and it will "lift" the belt off the motor spindle. Release the head lever, only one direction it will turn and remove the head. Turn the head over on its back, turn the KIRBY knob to release the old belt. Remove the brush guard by turning the two release fixtures. Remove the guard. Pry the brush out of the head. Remove the old belt. While the brush is out remove any build up of hair and lint off the ends that's where the bearings are. put a few drops of 3 in One oil on the ends. Put the new belt over the brush and re-install the brush into the head. the brush will go in only one way. With your finger pull the belt into the housing and rotate the KIRBY knob until the pawl inside grabs the belt. Re-install the brush guard by engaging the two metal pieces into the front of the head and pull down backwards over the head and rotate the holding clips back horizontal. re-install the powerhead on the machine, lock it in place and rotate the KIRBY knob clockwise. You should be all set!
Aug 23, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Dirt Devil M1100009 Reaction Soft Touch Cyclonic Upright Vacuum Cleaner Vacuum Logo
180 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
