Question about Yamaha 4500 Watt Electric Start Generator - EF5200DE
Generator runs but want generate no power - Yamaha 4500 Watt Electric Start Generator - EF5200DE
5 Suggested Answers
  • 154 Answers
SOURCE: Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Posted on Jun 14, 2009
  • 202 Answers
SOURCE: my generator might be broken
Check if a circuit breaker is tripped and reset it.
Posted on Apr 01, 2010
  • 26 Answers
Check the breakers.take it back if its brand new.
Posted on May 10, 2010
GeneratorDan
  • 44 Answers
SOURCE: my generator wont put out any power it runs great
What model is it??
Posted on Nov 06, 2010
The engine is running but does not have power.
If the generator has been sitting for a long time or was shut off with the load connected it has likely lost the residual magnetism that is required to excite the winding. This is a common problem. Always disconnect the load from the generator before stopping the engine!
The generator needs to be flashed. There are several was to achieve this, but safest would be to use an electric drill.
  • Connect an older style portable 120 volt drill to the running generator.
  • Make sure the drill is in forward not reverse
  • With the switch depressed rotate by hand the chuck of the drill in reverse
  • careful, the generator will flash, power up and rotate the drill in the forward direction..
Hope this helps?
  • Careful the generator will flash the windings and power up the drill
Mar 28, 2016 | Electrical Supplies
I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can check.
All Power America APG3535CN, 2800 Running Watts/3500 ...
www.amazon.com/...Power...Generator/.../B000U0OJ...
Amazon.com, Inc.I then call All Power and am told to give them one more day to get this worked out ....There is no styrofoam enclosure or crate to protect it, the generator is simply ...
NIKOTA 3500 WATT GENERATOR - YouTube
? 0:58
https://www.youtube.com/watch?v=NEeu9Y-0_KM
Aug 27, 2011 - Uploaded by mamasboypowersports
NIKOTA 3500 WATT GENERATOR. ... Diagnosing A GeneratorThat Has No Power Output. - Duration: 3:03. TheDIYGuyDOTnet 117,263 views.
I have a nikota 3500 watt generator and I am not getting any ...
www.fixya.com/support/t26062098-nikota_3500_watt_generator_am_not
2 hours ago - I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can ...
Generator outputs low variable voltage, ideas for troubleshooting ...
www.smokstak.com > ... > Generators & Motors General Discussion
Jan 20, 2016 | Electrical Supplies
Why would my generator engine runs great but it will not power any of my tools. what could be the problem?
With no load on the generator, take a voltage reading at the output plug of the generator, if there is no voltage, check to make sure that no breakers are tripped or fuses blown.
Sep 21, 2014 | NEC Mitsubishi MGE 4000 Generator ROU...
Onan 7000 generator runs but does not produce electric to rv
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
Mar 19, 2014 | Watts Onan Portable Generator - 4000 ,...
Ex 5000 sx generator, no power
Hello dear, would you consider buying a new generator? Generator Diesel Generator Cummins Generator Volvo Generator Perkins...
If you can start your generator normally, you can analyze the reasons through the following article:
Why Diesel Generator Fail to Start
Simple Ways to Deal with Diesel Generator Failure
Hope it works for you.
Sep 21, 2017 | Honda Electrical Supplies
Can my eb5000 generator run an electric 7hp compressor
7 horsepower is approx 5150 Watts so the compressor would be taking this power while running. On startup however the compressor can take a surge of upto 3 or 4 times this power so the generator wouldn't be able to supply this demand . In any case it's not advisable to run a compressor off a generator unless the generator is high powered, 20KVA or greater for 7hp.
Mar 31, 2011 | Honda Mmd 5000 Watt Generator W/ Engine...
Generator runs fine but doesn't get power to the air conditioer or fan which run ok when plugged into ac power
An air conditioner is an appliance that draws a fair amount of current. It would have to be a large generator to run an air con. Does the generator run smaller appliances like a jug for instance. If it does this means that it is working okay, it just can't handle the capacity of an air con.
Feb 11, 2011 | Watts Onan Portable Generator - 4000 ,...
Generator was running and quit generating power but the motor is running good
brushs might need to be polarized-hook jumper cables to a 12v battery and touch to the brush contacts it should work and renew your power out.
Dec 21, 2009 | Briggs & Stratton Power Products 5,550...
Yamaha 4500 Watt Electric Start Generator - EF5200DE Logo
44 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
