Question about Simplehuman 5X Sensor Vanity Mirror
Charge cord not tight/wont charge
You have to hold cord for it rto charge
How to install pull cord?
take off cap then take out old pull cord once done get a cord long enough some will hanging out when recoil rewinds rope next there is hole in rewind pulley make sure you find it then hard part rewind spring on recoil till it stop hold tight the unwind 2 winds hold on tight next slip cord trough houseing and through pull hole put screw driver threw holes in threw rehousing that will hold in place the pulley not the cord take a lighter heat the cord up this will keep the knot in place grab cord remove screw driver from houseing hold cord tight pull cord until knot is seated next two pulley slowly let reciol wind rope in until it stops should be cord hanging out grab hiold of cord next to recoil hole pull out for two pulley revolution hold there install handle on rope tie knot heat knot with lighter your done cut off excess rope reinstall cap and completey down let me no if you have problem i will help im the red neck i like helping people
Aug 28, 2014 | Garden
Mophie charger plug wont stay in
I had the same issue. I was able to trim the cable shell to get it to insert further and take better hold. I suspect some cables may work better than others but the design is poor as they have the jack on a curved corner. Had they angled it a little it would work better and actually work. They should also include a screen protector for the price. The case scrapes off standard protectors because of the tight fix, though the tight fit is good. I actually love the product though as it actually works. Just not enough real world testing.
Jan 20, 2014 | Apple iPhone Smartphone
Moved treadmill and now its not working
1) Test the outlett power wall, and rese the c.breaker from your home
2) Test the power cord for wires loose, break or burn with VOM
3) Reset the c. breaker from treadmill
4) See if there are some wires looses
5) Tight any wires connector very well.
6) See if there are some fuse blown inside,
7) Test again. Note: NOT use any extension cord. see the block diagram for help .
God bless you
May 20, 2012 | RTO Image 15.0R Treadmill Walking Belt
My dsi xl wont charge unless i wrap the cord TIGHTLY around it and now that wont work.
Your cord has a short in it. Wrapping the cord in ANY way, even around itself for safekeeping, slowly deteriorates the cord.
Aug 03, 2011 | Nintendo DSi XL Burgundy
I have a 92 camaro rs tbi and the alternator and the battery went bad and i just replaced them 2 days ago and now the battery is dead again and after i charge the battery it still wont hold a charge the...
take it back they have to replace it,they either have a 60-90 day warrenty also see if battery cables are tight.if you have a chrger see if battery holds a charge.
Aug 29, 2010 | Chevrolet Camaro Cars & Trucks
How do I replace broken pull start cord?
There are screws holding the top of the mower on, you should be able to remove those and lift them to get access to the cord. From there it is easy. just put new cord back the opposite of the way you removed it, making sure that you get it wrapped the correct direction. you can get a cord anywhere they sell mowers.
Apr 18, 2010 | RTO Toro Lawn Boy 21in Insight Series...
My computer is not recognizing the go pro cam whatsoever. Also the usb cord does not feel secure within the camera. What could the problems be?
Have the same problem. The USB plug will not go into the USB socket.
I can hold it in place enough to begin charging the battery, but will not transfer data.
Feb 25, 2010 | RTO Gopro Hero Wide Angle 5 170 Video...
Paslode battery wont hold charge.brought new battery, same thing.brought new charger, same thing. put battery in gun, fan runs and then the battery is flat again.
if you have bought a new battery and charger , and it still will not hold a charge. you might have bought a bad battery or charger , also the fan dosent allways run so the fan going off is not a sign of a dead battery. depress the trigger or safety and the fan should start up again
Feb 14, 2010 | RTO PasLode 900420 Impulse Framing Nailer
I am trying to replace the cord on my mower, but the cord wont spring back in when I attempt to start it. Please help
the spring below the cord 'spool' must be wound tight before new cord is attached.disconnect cord,wind spool in the direction cord would pull it when starting until it stops & hold it there[spring is wound] release it enough to align & attach cord.release spool & allow it to wind cord onto spool.replace cover.
Oct 11, 2009 | Garden
My phone wont charge
I have the same phone and bought a new charger and it still wont work, it's the phone
Sep 13, 2007 | Samsung SPH-M500 Cellular Phone
Simplehuman 5X Sensor Vanity Mirror Logo
734 people viewed this question
Top Simplehuman Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Simplehuman Furniture Expert? Answer questions, earn points and help others
