Question about Vacuums
Castor wheel fell off
Hoover whirlwind vacuum...the front wheels have fallen off and not going back on, should i use glue to stick them back into the axle?
5 Suggested Answers
Kazong
  • 152 Answers
SOURCE: Hoover upright vacuum information
cant help with manual but if i may why would u take it apart theres not much to service but to take the belt off turn the machine over and down by the roller there are a few screws take them out the cover should come off and thats it
Posted on Feb 06, 2008
SOURCE: The right front wheel came
Thank heavens for a husband who can fix anything--and save me a lot of money for repairs and advice!
Posted on Sep 23, 2008
SOURCE: how to install front wheels
Please be sure to unplug the vacuum before doing this. Pull the sides from top cover on the floor portion (Where the light is) and it pops right off. After the cover is off, step on the lever to tilt the handle back like you are going to sweep. Lay the handle all the way down to the floor to raise the bottom of the vacuum somewhat so you can reach under it. You should be able to push up on the front wheel assembly, it should be very loose. If you look on the top of the vacuum where you removed the cover you should see a clip that moves when you push up on the wheels. Carefully squeeze the clip to push it past the opening and the front wheel assembly should drop down to make removal possible. This works on the Breath Easy model.
Posted on Dec 18, 2008
  • 6 Answers
SOURCE: Front wheel assembly on a
Yes it is the cam actuator spring. It keeps tension on the height adjustment wheels. Hope this helps.
Posted on May 06, 2011
How do I attach castor wheels to the Hydro Advanced vacuum cleaner?
If the wheels came with the vacuum, there should be instructions.
Jul 14, 2014 | Kirby G4 Bagged Upright Vacuum
G series kirby ultimate the wheel fell off and its on the side with the height adjustment....all fell on to floor when it came apart....how does that wheel stay on is there a part missing or do you just...
I cleaned the end of rod and the hole in the wheel, and then forced the wheel back on the rod. A little bit of glue at the end of rod will help to keep wheel stay.
Apr 21, 2011 | Kirby G5 Bagged Upright Vacuum
Front wheel slips off shaft
Pull the wheel off. Look on the back side of the wheel - you will see 4 plastic pins sticking out (inside the wheel) Use a pen to push on them - this way you will remove the hub cap without damaging it. Under the hub cap you will find the screw. You will need a torx T20 or Phillips crew driver (depending on what type of screw is there) to attach the wheel to the shaft with the screw. You can use a bit of a nail polish on the screw thread to keep from coming off again. DO NOT use glue or too much of nail polish or no one will be able to get the wheel of if needed some time in the future.
If hub cap nor the screw is there - you can find it all HERE.
Good Luck,
Rocky
Mar 24, 2009 | Kirby G6 Bagged Upright Vacuum
Hoover Windtunnel Bagless bolt fell off
With this self propell series, the entire bottom needs to come apart to re-install the nut. if it is one month old I would highly recommend taking it in for warranty service. What plastic is melted?
Nov 02, 2008 | Hoover U6630-900 WindTunnel Bagless...
Hoover front wheels replacement
on the wheel assembly you will see on each end the studs with the flat ends on them,slide the studs in the slots and fold wheels forward and push in.in the middle at the front of the wheels you will see a flat catch ,push it up into the base right behind the brush roller and it will snap in
Oct 04, 2008 | Hoover Elite U5061-900 Bagged Upright...
How to install front wheels on upright hoover vacuum cleaner
Jul 24, 2008 | Hoover Vacuums
How to install front wheel assembly on Hoover Bagless windtunnel vaccuum
There is a spot that sticks up on the holder for the wheels, the hole in the spring goes there, then it fits between the holder and the base asm.04f5295.jpg
Feb 24, 2008 | Hoover U5753-900 WindTunnel Bagless...
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
