Question about Texas Instruments TI-84 Plus Calculator
How to calculate e on a ti calculator - Texas Instruments TI-84 Plus Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Raise e to the first power. On the TI84, press 2ND e^x 1 ENTER
Posted on Jun 08, 2014
TI-34 instructions
There are several calculators that have the TI-34 model number. I am not sure which one you are referring to, so I am giving you the link to the TI-34 calculator guide.
If that is not your calculator, go to education.ti.com to download the guide that pertains to the exact model of calculator you have.
Jun 26, 2012 | Texas Instruments TI-34 Scientific...
What is the different between ti-86 and ti-83
The 86 has more memory. It also has some advanced calculus capabilities the 83 doesn't. However you're much more likely to see examples for the 83 in textbooks and other references.
TI-83:
http://www.ticalc.org/basics/calculators/ti-83.html
TI-83 Plus:
http://www.ticalc.org/basics/calculators/ti-83plus.html
TI-86:
http://www.ticalc.org/basics/calculators/ti-86.html
Aug 09, 2011 | Texas Instruments TI-86 Calculator
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  1. Try a new set of AAA batteries.
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
Every time I turn on the calculator, it gives me this message: Waiting... Please install operating system now after a while, the screen changes to: ERROR! Press any key to turn unit off. Then turn unit...
Read the following from the TI knowledge Base. Hope it helps
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need to use the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
Oct 28, 2009 | Texas Instruments TI-84 Plus Silver...
Turned on calculator and screen reads operating system not found install OS now
Here it is from the horse's mouth (TI Knowledge base). Please read till the end.
I hope it helps.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Remove all of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Oct 27, 2009 | Texas Instruments TI-84 Plus Calculator
Screen displays small horizontal line when powered on that quickly fades away. Have changed batteries. When I do a reset (take one battery out, push delete while putting it back), the screen displays...
Here is what the Texas Instruments Knowledge Base has to say about your question.
I hope it helps.
Howdo I correct the Error Waiting...Please Install Calculator SoftwareNowmessage on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.Themost common cause of a transfer being interrupted is updatingthe operating system on a calculator with low batteries. Users will needtouse the TI Connectivity cable and the TI Connect to sendthe operating system to the calculator. Make sure to have thelatest version of TI Connect installed on the computer.
If themessage "Error! Press any key to turn unit off. Then turn unit back on."appears on the graphing calculator, quickly, remove one battery from thecalculator and reinstall it while the transfer is taking place.
Oct 26, 2009 | Texas Instruments TI-83 Plus Calculator
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to ti-cares@ti.com.
Oct 22, 2009 | Texas Instruments TI-83 Plus Calculator
Replaced the batteries and downloaded the software
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
Hope it helps.
Oct 05, 2009 | Texas Instruments TI-84 Plus Calculator
I cant do anything on my calculator.....when i turn it on it says "waiting... please install calculator software now." When i press the "on" key, it says, "ERROR! Press any key to turn the unit off. Then...
i've got a similar problem...my ti 84+ doesn't turns on anymore...reseting device didn't change anything. the ti-support wasn't that big help..
but its right, how to communicate with a calculator, that doesn't want to get turned on!??!.
Oct 01, 2006 | Texas Instruments TI-83 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
23 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
