Question about Magellan RoadMate 700 GPS Receiver
Weak reception, broken surface mount component
My Magellan Roadmate 700 recently started having problems acquiring and holding the satellite signal. I opened the unit to check for problems around the antenna and discovered that a surface mount capacitor or resistor had been broken off the circuit board. The pads are for a 1206 device, but there is no reference designator silk screened on the board. Consequently I don?t know if it was a capacitor or resistor. The area is next to the gold antenna connector in an area that is covered by a translucent tape. Does anyone know of a place where I can find a schematic? Thanks, Papawayne
Hi DanEz007
Thanks for the reply.  The broken part is a surface mount capacitor in the antenna circuit.  I will describe the circuit as best I can.  The signal from the antenna goes through a series circuit made up of a 470-Ohm resistor, 33K resistor and an inductor.  Connecting at the junction of the 470 and 33K resistors are 2 capacitors in parallel; their other end connects to ground.  Also in parallel to the series network is a capacitor.  The cap connection is from the antenna to the output of the inductor.  Now for the missing part; a capacitor connected between the junction of the 33K and the inductor and ground.
This series-parallel circuit connects to a 4-pin device. The only number on the device is "T79".
I know a verbal schematic is awkward, so if you would consider emailing me at waynenjoni@gmail.com I could send you a sketch of the circuit.  I assume that the missing cap was probably a small picofard cap used to tune the input.  Sure hope you can help.
Thanks,
Papawayne1
Posted on Oct 18, 2007
    Novelist:
    Scholar:
  • 86 Answers
You can not find any schematics for the Magellans.  The schematics are classified.  Even when repairing GPS's for Magellan we didn't receive full schematics.  If your talking about the RF cable connector on the I/O Board (the board attached to the rear housing), then it's an easy solder fix.  For the capacitor/resistor:  I'm not sure where you found the capacitor origin, but if it's black with four legs coming off and parallel with the IC then tell me and I'll msg you back the rest.
Posted on Oct 15, 2007
My Magellan Roadmate 3045 is not getting any signal. I turn it on, and it doesn't even attempt to acquire a signal. The satellite icon in the top right-hand corner of the menu which indicates signal...
Mine actually stopped working the same day you posted this. How strange is that? I have not been able to figure out what is wrong with it. Have you figured out a solution?
Aug 06, 2011 | Magellan Roadmate 3045 - uses Gomadic...
Road mate 700 won't pick up satellite signal
If this unit has an internal battery it may be bad, other wise I would reload the software or get a updated version of the operating software. Have you contacted Magellan?
Dec 03, 2010 | Magellan RoadMate 700 GPS Receiver
My Magellan Roadmate 700 is locked.
it can be bcoz the satellite is not working a the moment. or the computer navigation is broken.
so check both things
Jul 22, 2009 | Magellan RoadMate 700 GPS Receiver
No Satilite Signal
it is a dicontinued like mine roadmate700 and started losing sattilite signal like everyone says here ,i got upset i spent alot of money on it,then this happens, so i decided and bought the new magellan mastreo 4000 and just updated the software and no problems i love it,portable,thin light weight internal chargable battery that lasts 3hrs,the signal strenght is awsome,never had any problems,my advice junk it, the 700 like i did and purchase a new unit.this way it will save you alot of problems and headaches in the future,beleive me.
Aug 02, 2008 | Magellan RoadMate 700 GPS Receiver
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
Not getting reception...
I have repaired this problem many times,, send it in and I will provide estimate.
Bills Electronics Ltd
60 Elora St.
Mildmay ,Ontario
Canada,
N0G-2J0
Mar 14, 2008 | Magellan RoadMate 700 GPS Receiver
Roadmate 700/760 freezing/locking up
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.
Feb 29, 2008 | Magellan RoadMate 700 GPS Receiver
Unit will not acquire the satellite signs
FYI ....My Roadmate 760 would not aquire a signal, I went to diagnostic screen and found it was detecting/tracking 0/0 satellites. Held the plugged in unit out the window and within 10 seconds was tracking 7 satellites! Turned out my 1999 Olds Silhouette Van has a anti-glare filter inside the factory windshield that blocks GPS signals.My wifes 2001 Chevy Impala also has same type filter. Check your windshield, filter is visible inside glass to within about three inches of edges of glass. Worth a look.
Dec 29, 2007 | Magellan Roadmate 760 GPS Receiver
No satellite reception
open it up carefully and chk for the wire make sure it did not popped off .if it did resolder it and if does not work after that get a new unit.
Dec 20, 2007 | Magellan RoadMate 700 GPS Receiver
Keeps seeking but no GPS positioning
get a new unit like any magellan mastreo series or roadmate 800 ,i had a 700 they start having alot of problems after i did my research on here.
Sep 06, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
181 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
