Question about Panasonic Office Equipment & Supplies
Projector turns off after 5 mins - Panasonic Office Equipment & Supplies
What is wrong with Acer P7280 projector? The lamp goes out after 10 min. use, and red lamp error led turn on
the lamp must be ok
the ballast may be fault
or the mainboard is fault
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Jun 18, 2014 | Acer P7280 OEM Projector Lamp
The projector is powering off every 5-10 mins, then restarts after the next 5 mins.
1,the color starts to go out, it become the white and black ,
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 07, 2014 | BenQ MX710 3D Projector
My Epson EMP-TW20 projector has consistantly started cutting out 20 mins after being turned on, it then switches to stand by and I think the fans go on for about 5 mins. However, if I switch it straight...
clean it out with canned air. the dust keeps in the heat that the projector is trying to expell. you may need to replace the temp sensor, as the constant heat may have weakened the sensor.
Nov 01, 2009 | Epson EMP-TW20 LCD Projector
My in1 projecter keeps turning itself off
if the lamp has 2000 hors on it, it needs replacing. go into the menu and find out how many lamp hours are used. it could be the lamp and it could be the ballast.
Nov 23, 2008 | InFocus ScreenPlay 4805 Multimedia...
No powers ups
does the lamp try to fire up
check lamphouse and fan filter safety switches
Jan 08, 2008 | Sanyo PLC-SW30 Multimedia Projector
Panasonic PT-L759U
With the power on and the lamp off, hold the input button down on the projector then press and hold the power button for 5 seconds
Nov 16, 2007 | Panasonic PT-AE900U Multimedia Projector
Projector will not power on
Check your cooling solution wether its a fan malfunction or if it needs a new fan - or h20 cooling system
if not its either the power supply or something serious - send it to manifacture or go to a in-store repair
(it could be the dust protector)
Nov 16, 2007 | InFocus ScreenPlay 4805 Multimedia...
13 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
