Bosch SHV46C. At the end of the cycle the water is not draining out of the tub. I vac'ed out the water, removed the filters and checked for debris but found non.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump (not switching from recirculate to drain) , a wiring problem, or a faulty timer board can be cause the machine not draining.
The detergent dispenser for the Bosch SHV46C does not open during cycle and none of the detergent is...
(More)
The detergent dispenser for the Bosch SHV46C does not open during cycle and none of the detergent is used
detergent dispenser won't open during wash cycle I took it off and the spring seems to have ony one...
(More)
detergent dispenser won't open during wash cycle I took it off and the spring seems to have ony one conection point. How do I reinstall it so it will trigger properly.
hello
my bosch started leaking h20 fr4om bottom then it ran all night and now when you push start...
(More)
hello
my bosch started leaking h20 fr4om bottom then it ran all night and now when you push start button when door open you can hear motor run...
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
