Question about Garmin GPSMAP 295 GPS Receiver
Gpsmap 295 screen blurred - Garmin GPSMAP 295 GPS Receiver
4 Suggested Answers
  • 15 Answers
SOURCE: Tracking storage options GPSMAP 295
Every waypoint in the track has date/time, altitude and position. Second and subsequent waypoints will enable calculation and display of leg length, time, speed and direction between each par of points. The track can be displayed in 3D; in Google Earth for example. As far as I know there is no way to change the interval.
Posted on May 05, 2010
  • 15 Answers
SOURCE: Street Map Program for Garmin GPSMAP 295
Detailed road map data, with addresses, hotels, gas stations, etc. can be loaded into a data-card/cartridge/memory-card using Garmin's Mapsource software such as Metroguide or City Navigator. This can be changed as needed via a PC.
The 295 does not have driving routing/guidance through the streets as most of today's GPSs have, but it will show you exactly where you are on the street (but it should be switched to Road mode).
Driving routing is possible on the PC using Mapsource, but ithe route doesn't transfer well to the 295 because of the limits on waypoints.
Posted on May 06, 2010
  • 1833 Answers
SOURCE: need to purchase a back
You need to buy a replacement of back lite for your Gramin 295 gps receiver, for that you can follow these web links. Here you can find your products and related products. The links are :
https://buy.garmin.com/shop/,
http://www.bizrate.com/gps-accessories/garmin-replacement-parts/,
http://www.gpscity.com/garmin-replacement-parts-for-gtm2x-reviews.html.
hope you will find your require parts.
Posted on Mar 27, 2011
How to set time and date on GPSMAP 295
Set the time zone and daylight savings according to the instructions on page 76 of this manual. The time and date are automatically set from the information received from the GPS satellites.
Jan 28, 2013 | Garmin GPSMAP 295 GPS Receiver
Where do i go to down load update for my gps 295. garmin said thay dont support this unit. thanks joe
Joe,
The Garmin "GPSMap 295" is at, as far as Garmin is concerned anyway, "end of life". This means Garmin will no longer support, repair, etc. this product. C'est la vie.
Garmin's older product lines lack the hardware to decompress the new "NT" (New Technology) maps that Navtek (the map company) is producing now. The NT maps are compressed so that they would fit on smaller capacity memory cards. By doing this, the maps required Garmin to include hardware (special designed circuitry) that could quickly decompress these maps "on the fly" for display. The much of Garmin's older GPSMap & StreetPilot lines predate this hardware requirement.
Our "still-functioning" GPSMap & StreetPilot GPSr will still pinpoint our location on the Earth as always - but lack the latest & greatest maps. You should review the maps that your GPSr can use and choose the one you prefer. I switched mine to display topographical maps. These show many of the road names like the City Navigator maps do, but lack important things like the POIs and routing. If you can do without them, this could be good enough. If you can't, you'll need to decide on whether the last non-NT map version is sufficient or purchase a new GPS that can accept the maps you want to put into it.
I hope this helps and good luck!
Sep 06, 2011 | Garmin GPSMAP 295 GPS Receiver
GPSmap 296 doesn't show any satellite signal
Check that the date shown on the unit is correct. If not, choose autolocate and allow about 10 minutes for the unit to find satellites. If this works, then the internal lithium ion battery is defective.
Jun 02, 2010 | Garmin GPSMAP 295 GPS Receiver
How do I start the Simulator in the Garmin 295 ?
Press the menu button twice than choose from the resulting menu.
The manual is available from garmin.com
Mar 15, 2010 | Garmin GPSMAP 295 GPS Receiver
Jul 13, 2009 | Garmin GPSMAP 295 GPS Receiver
Turns off with pressure applied to top of unit
I have discovered an intermittent problem on my 10 year old 295 when powered by batteries.
It appears that the chrome plating is de-laminating from the battery contacts that are either side of the back panel attachment hole. At first glance it looks perfect but if you run a fingernail or other small item across the face of the contact you will see and hear a movement as if there a a loose layer of foil over it. This is causing all manner of faults including 'external power lost, shut-down in 30 seconds' when the external power was not even connected at all!
Jun 08, 2009 | Garmin GPSMAP 295 GPS Receiver
Does Garmin GPS 295 contains Maps for Africa and the Middle East
Hi there -
The GPSMap 295 can only have one region at a time - North America, South America, etc. You can purchase an updated database specifically for Africa and the Middle East - it's about $50 USD. It will erase whatever region you have in there right now (you can't store Africa/MidEast with America, for instance. It's one at a time.)
The Garmin Website:
http://shop.garmin.com/aviation/databases/
lets you download new Jeppesen databases to your GPSMap 295. Select your model, then select which region you want.
***Before you buy:*** You'll have to have the data cable to connect it to your computer. Without that, you will have no way to update the maps and database.
If you do have the data cable, the process is very easy - just follow the instructions carefully, and make sure all the numbers they ask you for are correct. I just did mine today. Good luck!
Mar 24, 2009 | Garmin GPSMAP 295 GPS Receiver
Inaccurate Garmin GPS
Have you enabled the 'WAAS' option?
This improves accuracy greatly
Jan 19, 2009 | Garmin GPSMAP 295 GPS Receiver
Battery power trouble
Jan 03, 2009 | Garmin GPSMAP 295 GPS Receiver
Nov 29, 2007 | Garmin GPSMAP 295 GPS Receiver
Garmin GPSMAP 295 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
