Question about NetGear XE102 Powerline Ethernet Adapter (XE102US) (D85639) Bridge
Netgear ethernet xe102
I have several connected around the house and out to the shed.................they all work around the house but when I use my laptop in the shed.........It finds the netgear signal and declares it self connected but i cannot bring up anything in browser..any ideas...thankyou
You have to be on the same transformer leg Xmitter and reciver try moving the input device to a diffeent outlet. or use one of the ethernet only units to see if you have etherne tconnectivity, also there is a pricatical distance limitation of about 600 feet. are you in that range. Best of Luck Graeme at
Posted on Oct 15, 2007
All the indicators are on but network is not
1. first check that are you able to go online with router
2. connect both adapter in the same room where the router is connected
Mar 02, 2010 | NetGear XE102 Powerline Ethernet Adapter...
I have MacBook and it is not recognizing the ethernet connection
1. First check the light status of the XE102.
2. Then hard reset the Xe102
3. As this is a plug n play device all the lights should come on.
4. In case if the lights wont come on.
5. Check the powerline ..
6. And if that will not work , get a new adapter or replace the existing one from netgear ( 1-888-638-4327 )
Jan 26, 2010 | NetGear Powerline XE102 Ethernet Bridge...
Only power light NetGear XE102
I was never a big fan on thos plug in ethernet devices. I would either go wireless or run hard line to the computer.
Dec 25, 2009 | NetGear XE102 Powerline Ethernet Adapter...
Hi, why isn't it possible to have the devices linked over a multiway connector?
It is, but due to the electrical requirements of Ethernet, it's not as simple as having one of those telephone Y-connectors. The multiple connector is called an ethernet switch, and can be had for $20-30.
Nov 09, 2009 | NetGear XE102 Powerline Ethernet Adapter...
No lights come on when I switch on my XE102.
Though, it is not repairable, yuu may contact NETGEAR to get the unit replaced if it is still under warranty. Contact them
Aug 08, 2009 | NetGear XE102 Powerline Ethernet Adapter...
Netgear wall plug XE102 stops working when downloading
It seems to be an issue either with the powerline adapters or the electric line. Swap the devices and check if it helps. Also, disable encryption utility if being used
Try connectig both teh devices in the same room and check the download speed
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 24, 2009 | NetGear Powerline XE102 Ethernet Bridge...
The middle light on my netgear ethernet bridge xe102 wont stay on
-- Xe102 device is simply a plug n play device
-- so if the connection light shut off after some time
-- first hard resett the powerline adapter
-- and after that get the powerline checked
-- If that doesnt work there is no specific configuration
get the adapter replaced ..
Jul 01, 2009 | Powerline Netgear XE102 Ethernet Bridge...
I purchased two netgear wall plugged bridge XE102. They worked fine for one month. Now I get messages on my computer do not detect homeplug adapter. On my TV it say's is not hooked to the internet. What is...
I had the exact same problem those branded ones at our shop where one just stopped working all together.
THeres a couple of things to rule out so you can try some steps to figure it out.
Try changing the port on the router where the first plug is hooked into, if you can, try a direct connection without the plugs aswell. Also, try inserting the plugs in different outlets and see if anything has changed. If they're only a month old, they are still under warranty and you could get them replaced either through ytour place of purchase or from netgear aswell.
Apr 26, 2009 | NetGear XE102 Powerline Ethernet Adapter...
Trouble installing XE102 Powerline
there wasn't actually any problem with the device. For these bridges to work, you need to be on the same phase of the wiring. If the devices are on different phases then they can't communicate. But I still couldn't get the encryption to work. Netgear support doesn't seemed to be bothered with that...they told me to ignore it.
Dec 16, 2008 | NetGear XE102 Powerline Ethernet Adapter...
Netgear xe102 isnot picking up an ip address
-- Xe102 is a plug n play powerline device
-- there is no specific configuration required for that .
-- try hard resetting from the reset hole on the back of the device
-- then get the powerline checked
-- check the light status of the powerline device.
And if the problem still persists , upgrade the powerline device ..
Follow the link below ::
Nov 15, 2008 | NetGear XE102 Powerline Ethernet Adapter...
NetGear XE102 Powerline Ethernet Adapter (XE102US) (D85639) Bridge Logo
447 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
