Question about HP Color LaserJet 2600n Printer
Print one job Forever
My HP 2600n print one job nonstop, while it was given a command to print only one copy. I remove paper as the only solution to stop it because even cancel does not stop it. Once i put the papers back it starts over again printing countless copies of the sama job. I reset it to factory setting and tried to print a new job, it printed it and restarted printing the previous one a million copies again. What can be going wrong with it??????
  • cdoublen Oct 09, 2007
    I unistall the printer to and reinstalled it, but problem persisted. I have been chating with an online HP tech assistant he/she hasn't seemed to be a help. What other course of action could be taken?
    Novelist:
    Scholar:
  • 167 Answers
You should remove the printer driver and reinstall the printer driver. If that does not help consider re-installing windows. And if the same occurs again, get help from HP service at your area. or you can get support from the manufacturer's website.
Posted on Oct 09, 2007
  • Deepu Amalan
    Deepu Amalan Oct 25, 2007
    I suggest you to connect the printer to another system if you can arrange it. (even a laptop will suffice) Then install the printer if the same problem appears, get your printer serviced from a qulified technician.
    If the problem is solved when you connect the printer to a new system, try formatting and reinstalling windows on your machine.
SOURCE:
Printer jammed and paper was removed but now it says paper jam and won't print from a command from the computer
hi go into control panel find printer settings u will have to clear any printing commands in c whats printing........good luck
Sep 04, 2015 | HP PSC 1315 All-In-One InkJet Printer
Why does some txt print when using ctrl shift print to print a document or email and some lines do not print at all?
There are two way email e-print.
A> Open email and select print area and see preview, if preview ok then you given print. If not ok then go to printer setting option and set printer paper or text. Then see print preview if ok then given print.
B> Second option is copy email print job any doc file or then print select and command given. But print before also check it print preview.
If any issue create i share a print related problems link please visit and read it. I hope solved your issues.
Source..ePrint Job Did Not Print
Thanks,
HP Phone Number
Jun 23, 2014 | HP Officejet Pro 8600 e-All-in-One Printer
Hello I have an HP 2600n and would like to print on 5x7 paper, is this a possibility with this printer? it seems that it will pull the paper through but nothing is printed
Copied this from the specification on HP site.
It would appear not to take 5 x 7. It's the 7" is to small, 8.5 is the smallest.
Media sizes, std.
Letter, legal, executive, No. 10 envelopes, Monarch envelopes
Media sizes, custom
Tray 1, 2, 3: 3 x 5 to 8.5 x 14 in
Media types
Paper (plain, letterhead, prepunched, bond, color, rough, preprinted, recycled), HP Color Laser Glossy Photo Paper, HP Color Laser Glossy Brochure Paper, HP Color Laser Matte Brochure Paper, HP Color Laser Matte Photo & Imaging Paper, HP Color Laser Soft Gloss Presentation Paper, HP color laser transparencies, labels, envelopes, cardstock
Nov 30, 2010 | HP Color LaserJet 2600n Printer
My HP Laserjet 1020 printer does not give printout from a remote computer. Even the print command given by local host computer does not work. The print commands given earlier does not get deleted when...
First you clear the pending print job
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer. if still you fail to print follow this steps to troubleshoot the issue.
first you make sure your printer is working fine just remove the test print form going to printer and faxes option just right click on it and give test print if it is print that means your application have some problem from where you removing print out if test page is not coming then you need to reinstall the drive of printer.
Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | HP LaserJet 1020 Printer
HP 2600n will not except print jobs.
just reset the printer to factory settings , use the menu to find factory settings .
Feb 03, 2009 | HP Color LaserJet 2600n Printer
My printer,scanner and copier started behaving funny when i installed Vista Business. it prints a countless number of pages when a command is given.
Hi again,
I sugest that you download a new driver from here: - you have to join them in order to get the driver, but its free. NOTE, you problem might bee that you have installed a Vista32 driver on a Vista64 computer, please be sure to download and install the right one.
regards /Teis
Dec 29, 2008 | Office Equipment & Supplies
My printer won't print from the computer command; it will print fax or copy a paper.
MY PRINTER WONT PRINT FROM THE COMPUTER. IT WILL COPY A PAPER, BUT NOTHING FROM THE COMPUTER COMMAND.
Nov 04, 2008 | HP Officejet 5510 All-In-One Thermal...
Hp 2600n laserjet will not print
Check the printer if no light coming during power on. If it is coming, and no sound for rolling printer after giving any command.. or blinking light when print command is send, then check the top cover for any paper jam and firmly closed.
Clean the toner/cartridge and also internal part of printer with a blower/Vaccum cleaner.. then with a cotton or cloth.
Let me know the status after this, so I can help you out.
Oct 21, 2008 | HP Color LaserJet 2600n Printer
Error message on HP 2600n
Connect to it through usb/parallel from your laptop, If this works then check your settings through your wireless connections,Hope that helps
Andy
Jul 10, 2008 | HP Color LaserJet 2600n Printer
Printing Problem
You can print the Coniguration page and demos?
If so, somehow you may the settings to the printer wrong.
If you select , file, then print, see that the proper printer is selected.
If you can print those other pages, the printer and connection is fine. There is some setting not sending the print job from the applications.
Really sounds like the printer has be deselected at the default printer
Dec 07, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
88 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
