Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
Recording Paper Cassette
Hello...I have error code 011 and according to the manual...it says to install recording paper cassette...what is this and where do I find it? Any help would be appreciated. Thanks, Amy
  • crystalg_21 Dec 11, 2007
    I keep getting a msg that I need to check the casette code 011. I have tried to keep fixing the paper casette as well as the paper and the toner. It is not working... The error light keeps flashing..
    Sergeant:
  • 284 Answers
Error code 11 means that it does not see the cassette in the machine,. there is a tab on the back of the cassette that is broken . thats why your getting that code.
if you leave me a msg that you want to fix this i will contact you
Posted on Sep 26, 2008
I fixed this by taking the paper tray out and putting it back in. I know it has nothing to do with a cassette, but it worked. I guess they call a tray a cassette. Strange.
Posted on Nov 21, 2007
SOURCE:
What does error code 011 mean?
error 011 normally means the paper cassette is not fitted properly. Usually the cassette(paper tray) sensor is out of place or the cassette is damaged.
Jan 06, 2015 | Office Equipment & Supplies
I am connecting and it tells me code 011 error
011 nornally means the paper cassette is not fitted properly. Usually the cassette sensor is out of place or the lug on the cassette is damaged.
Jul 26, 2014 | Office Equipment & Supplies
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Alarm - check cassette info code 011 - what is
The tab on the base of the paper cassette is broken off.
How to cheat it:
Remove the paper cassette
remove the tray in the back
remove the toner cartridge
set the machine upright
Wad up a small piece of electrical tape and shove it into the small black u-shaped sensor on the left side bottom.
it should work OK after this.
Nov 20, 2009 | Panasonic Office Equipment & Supplies
What doe he code 011 mean and how do we fix it?
Error 011 indicates an error with the recording paper cassette. Re-install the cassette to clear the error. It's basically the bin that holds the paper that the paper tray leads into. Please post back with any problems or questions or just to rate the solution. Thanks very much!
Greg
Aug 10, 2009 | Panasonic UF-590 Plain Paper Laser Fax
We cannot recieve faxes check cassette error code 011
The small tip on the left side of the paper cassette is broken off.
wad up a small piece of electrical tape up and stick it into the black u-shaped sensor hole where the tip used to go in.
Jul 07, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Fax machine with error code. Panasonic UF-780. Error: "Check cassette info code = 011"
you broke the tab on the back of the paper cassette. if you look in where the cassette goes on the back left you will see a hole with a sensor that looks kinda like a upside down letter U . put paper inbetween the sensor and the machine should say out of paper and put the cassette back and you should be fine
Dec 29, 2008 | Panasonic Panafax UF-780 Plain Paper Laser...
How to fix this code????
there is a little tab on the cassette that is broken. leave me a way to email or talk to you and this could be resolved
Sep 24, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Jun 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
475 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
