Question about Lexmark All-in-One Printer with PictBridge
Printer wont print
This may be simple to fix but my lexmark 2500 combonation scan/print/copy wont print i installed/uninstalled the software several times even took the driver from main site but when i choose my printer from control panel it shows a lexmark fax icon and a fax menu comes up my copmuter is a dell inspirion 1721 laptop and it runs on vista if you can help i would appreciate it thanks
  • 1 more comment
  • adam west Oct 10, 2007
    ok i will if you find anything do the same thanx.
  • Anonymous Dec 24, 2007
    i deleted several things off my computor and my lexmark inmaging studio was one. So put back in start up disc and it will not re setup. All i get is that the Wizard is installing it , BUT IT AINT ,It says it has but has not.
    i want my imaging studio back so i can print documents and photos. HELP
    im 66 and a little thick ///?? all plugs and things are working.
  • gordonio Dec 24, 2007
    that comment above signed guest is me in case u reply
    GORDONIO
I just bought a different printer. the staples people immediately agreed to take it back after i told them the make and model. you should do the same
Posted on Nov 01, 2007
SOURCE:
I can't get my lexmark X7170 to scan. It keeps giving me a communication problem. I have checked all cables and cords and restart like they said to and I uninstalled and reinstalled printer drivers and I...
Hello. Uninstall the software properly by going to Start Menu > All Programs > Lexmark Series folder > Tools > Uninstall. Restart pc. Probably, the software got corrupted that's why you are having problem with scanning. Reinstall the software by using the cd only this time. The scan software can only be installed using the installation cd that came with the printer.
Apr 01, 2010 | Lexmark X7170 All-In-One InkJet Printer
LexmarkX5495 won't scan....can you help?
go to www.isohunt.com and download driver detective with key. Install driver detective. And let it to search for the drivers your system needs to operate any hardware. When it searches the drivers for your MFP then install it.
cheers
Dec 07, 2008 | Lexmark X5495 Printer
Printer installed & ready but wont print
found solution: driver software had an error while installing & only installed half the proper software. i had to uninstall the lexmark 5200 serious software completely & download it again from the lexmark website.
i talked to the lexmark customer service live chat line on their website & found out what the problem was. they are very helpful, i highly recommend using it if you have a problem with your lexmark product!
pretty simple solution, its just a little time consuming.
Nov 22, 2008 | Lexmark X5250 All-In-One InkJet Printer
Lexmark Printer Install - No Communication Error
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jul 19, 2008 | Lexmark X1150 All-In-One InkJet Printer
is the printer in its own USB port? Some printers that "talk back" to the PC do not like to share a port so do not have it on a USB HUB.
Apr 17, 2008 | Lexmark X2500 All-In-One Printer
Not printing or scanning at high resolution
If the Lexmark software doesn't work you could just try using other software. Picasa http://picasa.google.com is a free photo management software and does a great job of printing photos. You can scan from an application like Word or using the "Get Picture using Scanner Wizard" menu that shows up when you right click the Scanner in My Computer in Windows.
Sep 29, 2007 | Lexmark P4350 All-In-One InkJet Printer
My 4 in 1 wont scan but does print
Before we give up on the scanning/copying ability of your machine. Try unplugging the machine from the wall and from the computer for at least a couple minutes. If that doesn't work, You may also check for a factory reset switch or reset mode you can choose. http://downloads.lexmark.com/cgi-perl/downloads.cgi?category=Drivers&ccs=229:1:0:94:0:0&os_group=WinXP&searchLang=en Last but not least. Uninstall the printer again, unplug it from the wall and computer. Make sure you restart the machine and even shut it down before trying to reinstall the drivers. The above site has a patch for the scanner. Not sure if its what may be ailing yours. Let me know what happens. Good Luck, Tim
Mar 01, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark All-in-One Printer with PictBridge Logo
48 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
