Question about Ricoh Aficio 1022 All-In-One Laser Printer
Free service manual on infotec 4182mf digital copier
Anyone know where I can download a free service manual for gestetner f270
This site sells one. 12.99,
http://www.service-manual.net/ashop/catalogue.php?product=19440
Are all these models similar?
  • RICOH: FAX1120L, FAX1130L, FAX1160L, FAX1170L, FAX2210L
  • GESTETNER: F101, F102, F230, F250, F270
  • INFOTEC: IF2050, IF3030, IF3035
  • LANIER: LF110, LF115M LF120, LF125M, LF215M
  • NASHUATEC: F101, F102, F230, F250, F270
  • REX ROTARY: F101, F102, F230, F250, F270
  • SAVIN: 3710, 3810, 3820
  • Jan 01, 2018 | Gestetner Office Equipment & Supplies
    SC551 error on Infotec IS2220D same as aficio 2020D
    it must be a small damage in capacitors in power supply
    Mar 25, 2008 | Ricoh Aficio 2020D Copier
    Infotec fax 3674
    call a service center
    Jul 05, 2013 | Office Equipment & Supplies
    I bought second hand Infotec-Ricoh 4452MF copiër no operating manual how can I get one
    Go to Ricoh's website and search under manuals, documentation and drivers.
    -David.
    Oct 30, 2010 | Ricoh Office Equipment & Supplies
    How can reset fixing error for gestetner copier
    The Gestetner and Infotec copiers is based the RICOH.Please try the Ricoh sercice enter code (press total clear key(yellow) -1-0-7 and press and hold down the C key more 4 second.Eneter in the service mode and turn OFF the copiers,unplugged the cords.Wait 10 sec.amd plug in the cords and turn ON the power switch.If is not good the 107 code try 104 or 102.
    Aug 19, 2009 | Gestetner Office Equipment & Supplies
    Infotec 5221 displays a E-5 symbol
    E-codes (E1-E7)are displayed im the copy counter.To display both digits of the E code press the Enter key.When service call E5 conditions occur,they cannot be cleared by turning OFF/ON the main switch for safety reasons.Ehe following procedure must be performed to clear these service call condition:
    Turn ON the main switch.
    Turn DIP switch 101-1 ON and OFF.
    Turn the main switch OFF and ON.
    Code E 52 Fusing lamp warm up error.Causes:thermistor open,fusing lamp open,therofuse open,power supply/ac drive board defective.
    Code 53 Fusing lamp overheat.Causes:thermistor short,power supply defective,main board defective.
    Code 55 Fusing thermistor open.Causes:thermistor open,main board defective,power supply/ac drive board defective.
    Aug 14, 2009 | Ricoh Office Equipment & Supplies
    Printer shows error CH551
    Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
    If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
    May 21, 2009 | Ricoh Aficio 1013F Copier
    Infotec IS 2220D Copier (same as aficio 1022 i think) SC551 Error
    Start by pressing clear modes, 1, 0, 7, and press and hold clear/stop. enter copy sp, select 7 fot data log, scroll to 7807, and execute. exit all the way out, and recycle the power. See if that does not fix your problem.
    Mar 25, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
    Ricoh Aficio 1022 All-In-One Laser Printer Logo
    44 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    Adorjani Laszlo
    quennie732
    Michel
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
