Error code SC390 on infotec 4182mf digital copier
Solution
drichards
  • 87 Answers
SOURCE: Infotec IS 2220D Copier (same as aficio 1022 i think) SC551 Error
Start by pressing clear modes, 1, 0, 7, and press and hold clear/stop. enter copy sp, select 7 fot data log, scroll to 7807, and execute. exit all the way out, and recycle the power. See if that does not fix your problem.
Posted on Apr 01, 2008
  • 62 Answers
SOURCE: error code oo7 in digital copier
The fixing film heater is serviceable and requires replacement.
Posted on Jun 19, 2008
  • 62 Answers
SOURCE: canon ir 2022 digital copier error code E001
how many blinks do you see in the led indicator? if it is 5 blinks then the problem is the printhead. if it is 2 blinks, then problem is in the feeding mechanism. if the problem is the later, then you might have to bring the unit to an authorize service center to have it checked.
Posted on Feb 18, 2009
ZJLimited
  • 17970 Answers
SOURCE: Copier: Infotec 5321 DZ Problem is
E-5-42 Total Counter Connection
1. Total Counter connector disconnected.
2. Total Counter defective.
3. SPC PCB connector disconnected.
4. SPC PCB defective.
If you have the knowed, do it and test it, if not, contact techinician service.
Posted on Mar 14, 2011
Daniel S
  • 4323 Answers
SOURCE: How do I fix error
Hi
SC543 error means Fuser Overheat Error 1 (Software) and is displayed due to hot roller fusing lamp that overheats. You can try turning off & unplugging the copier for 10-20 minutes to check if error code resets. If the issue remains then make sure the fuser units is fine and replace the part that is bad. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 24, 2011
Error message sc390
SC390: TD sensor error
-Definition- [B]
The TD sensor outputs less than 0.5V or more than 4.0V 10 times consecutively
during copying.
- Possible causes -
· TD sensor abnormal
· Poor connection of the PCU
Jul 07, 2011 | Ricoh Office Equipment & Supplies
SC551 error on Infotec IS2220D same as aficio 2020D
it must be a small damage in capacitors in power supply
Mar 25, 2008 | Ricoh Aficio 2020D Copier
Error code sc320 showing on infotec 4151mf
That is a polygon motor error.
This motor is from the Laser Unit. Probably you have to change it.
If you do not have technical training i advise you to call your provider.
Mar 11, 2011 | Ricoh Aficio 250 Copier
Sc390
SC390 = Toner Density Sensor abormality
Possible causes:
  • Poor concentration of developer
  • Toner density sensor faulty
Are the prints/copies coming out ok? If the copies are very faint or heavily overtoned then changing the developer may cure the error code. If the copies look OK then you probably need to get the toner density sensor replaced by an engineer.
Hope this helps.
Feb 10, 2011 | Ricoh Aficio 450 Copier
Sc390
- Possible causes -
Dec 30, 2010 | Ricoh Aficio MP 1600L Black and White...
Error code sc202 on infotec isc615g
SC202 is a problem with what is called the polygon motor, It is the motor in the laser unit and has most likely failed.
Jul 14, 2010 | Ricoh Aficio MP 161SPF Color Copier
Infotec 5221 displays a E-5 symbol
E-codes (E1-E7)are displayed im the copy counter.To display both digits of the E code press the Enter key.When service call E5 conditions occur,they cannot be cleared by turning OFF/ON the main switch for safety reasons.Ehe following procedure must be performed to clear these service call condition:
Turn ON the main switch.
Turn DIP switch 101-1 ON and OFF.
Turn the main switch OFF and ON.
Code E 52 Fusing lamp warm up error.Causes:thermistor open,fusing lamp open,therofuse open,power supply/ac drive board defective.
Code 53 Fusing lamp overheat.Causes:thermistor short,power supply defective,main board defective.
Code 55 Fusing thermistor open.Causes:thermistor open,main board defective,power supply/ac drive board defective.
Aug 14, 2009 | Ricoh Office Equipment & Supplies
The copier warms up and comes up with an error code of sc173
please precise which is the brand and model
by the code it seems to be a ricoh,nashuatec,lanier,infotec,rex-rotary,gestetner
but you have to specify the model
Mar 19, 2009 | Office Equipment & Supplies
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Mar 25, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
jasbo
jasbo
