Question about Sharp AR 201 Copier
Red light still on and blinking, Add toner - Sharp AR 201 Copier
2 Suggested Answers
SOURCE: add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Posted on Nov 10, 2008
Sharp Ar-5516 toner light problem continue blinking
If the toner light has a line under it your waste toner container is full and needs to be emptied.
May 04, 2016 | Sharp Office Equipment & Supplies
I am using samsung Ml 1640 Mono Laser Printer .After finishing Toner Ink I refilled it and set the toner into the printer . Then both of the lights Green & Red light is glowing but the Red light is...
Samsung uses a chip that senses when the cartridge has ended its service life, the chip is located in the cartridge itself, refilling toner won't help, replace the cartridge with a new one. hope this helps ;-)
Feb 03, 2011 | Samsung ML-1640 Monochrome Laser Printer
I have insalled new toner and the printer still has a blinking red light, i restarted the printer and nothing...help.
i have insalled new toner and the printer still has a blinking red light, i restarted the printer and nothing...help
Jan 31, 2011 | OKI C3400n Laser Printer
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Aug 02, 2010 | Samsung ML-2240 Laser Printer
ML-2510 Laser Printer : persistent blinking red light
Dear
This problem you will be noticed when toner is 90% empty.
Does the printer is functioning or No. If yes the problem is 90% toner is finished.[10% toner remaining alert]
If printer is not functioning Please change the toner from Genuine dealer. Else your printer fails due to non genuine and refilled toner.
Nov 11, 2009 | Office Equipment & Supplies
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
Samsung printer ML 2510 series
Maybe the toner is low... According to the manual, a blinking red light:
• A minor error is occurring and
the printer is waiting for the error
to be cleared. When the problem
is cleared, the printer resumes
printing.
• The toner cartridge is low. Order
a new toner cartridge. You can
temporarily improve print quality
by redistributing the toner. See
page 8.3.
• The toner is totally exhausted.
Remove the old toner cartridge
and install a new one. See page
8.4.
• The toner cartridge reached the
end of its life.
Feb 24, 2009 | Samsung ML-2510 Laser Printer
The start button won't turn green when power turned on.
if the machine needs toner you will be able to change paper size & reduction but the machine will not come to ready[green ready light lit]. so if the machine keeps running after you turn it on it needs toner. if you leave it on for lets say 15 min. does it give you an add toner light or an error code?
Dec 15, 2008 | Sharp AR-160 Copier
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Sharp AR 201 Copier Logo
19 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
