Question about AcerView 211C Monitor
Picture collapsed into a 1inch vertical bar and now gone altogether.
Any ideas on what component would be the culprit? Heard a small pop at the time it failed. Can't see any damaged components on the main board. Guessing it's in the horizontal sync area? any help appreciated, may be a common fault with these models. AJ
  • 661 Answers
Sounds like your coil driver has failed (these are the magnetic coils that steer the picture)
Posted on Oct 09, 2007
6ya staff
SOURCE:
My TV picture has collapsed to a single horizontal line
If it is an standar analog tv, I'm sorry to tell you but, is time to get a new one.
Dec 05, 2009 | Panasonic Televison & Video
Mitsubishi vs 55601 picture has gone out. It was
I have found several of the vertical deflection caps to be off value as well as the vertical chip to be defective.First after pulling the chassis (mark plugs and sockets that have no id numbers with a mark a lot) look with magnifier around vertical and hi section for circuit board cracks that need resoldered.Hope this helps.
Technition
Nov 17, 2009 | Mitsubishi VS-55601 55" Rear Projection...
I Heard a loud pop and then my picture was like it compacted from the top to the bottom into one tiny line across the screen.
Hi! the loud pop seems that an electronic parts got busted on the vertical section because you have mentioned a horizontal line on the screen. its either the electrolytic capacitor or the vertical ic itself is the culprit.
Sep 17, 2009 | Televison & Video
Picture appears only as a thin, horizontal line...
chk vertical amp /vertical drive i/p from oscillator/power to it/power to vertical amp/chk dry joints-hot area/look at vertcal amp capacitors-swelling etc
Jul 04, 2009 | Akai Televison & Video
Vertical collapse of picture then no picture
You most likely don't need to replace a board. You should solder the bottom of the vertical output, it probably has bad connections. If you don't know where the vertical output is, give me a model number and i will give you a location, or take a picture of the deflection board and i will circle it.
Tim Nolan
Sep 16, 2008 | Hitachi 53SBX59B 53" Rear Projection...
Vertical Collapse
genrally vertical collapse indicates failure of virtical ic. or related components
Jan 03, 2008 | Toshiba TP50H50 50" Rear Projection...
JVC TV
civilman, the first set has either no high voltage or is collapsed vertically, until someone checks for high voltage there is no concrete answer, the AV27730 is vertical collapse from your description, either the voltage to the vertical IC is missing or the vertical IC has failed, not a big deal cost-wise, hope this answers your questions, if not e-mail me back, good luck, BMW Rider
Dec 20, 2007 | JVC AV-27730 27" TV
Rca 27v41st blue at top of screen, picture moved down
No, you have a vertical collapse problem only correctiable by changing internal components. Sorry :-(
Sep 14, 2007 | RCA 27V520T 27" TV
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Open Questions:
See all AcerView 211C Monitor Questions
AcerView 211C Monitor Logo
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
