Question about LaCie d2 Extreme 250GB External with Triple Interface USB 2.0/Firewire 400/800 - 300790U ... Hard Drive
Lacie hard drive light not turning on - LaCie d2 Extreme 250GB External with Triple Interface USB 2.0/Firewire 400/800 - 300790U ... Hard Drive
SOURCE: LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
Posted on Jun 10, 2007
Beni S-P
  • 1006 Answers
SOURCE: lacie hard drive
The problem is just external...Hdd is fine..Just buy new external couse there is no way to repair it
Posted on Jan 27, 2008
SOURCE: Lacie 500Gb Hard Drive Porsche design
Hallo,
my disk, when on, is not recognised by Windows while the light is flashing between yellow and orange fast (like a car's flash -faster-). please could anyone help me? - i need my data!
Thank you.
Posted on Sep 29, 2008
  • 832 Answers
SOURCE: imac is not detecting my LaCie External Hard Drive
Do you have a CD disc software installer of your external hard drive (F.A. Porshe 160GB).? If you got it, you must reinstall it, so that your Imac can detect it. Otherwise, find it at the internet and download it.
The power failure could have damage some stored data about your External Hard Drive in your Imac. That's why, you have to reinstall it. Send us your e-mail comments for us.
Posted on Oct 17, 2009
  • 69 Answers
SOURCE: My lacie hard drive is not spinning up. the light
fisrt of all try to connect the hdd without adapter to a desktop computer to see if is detected usually the red-green light ocures when is a problem with the hard drive but you might be lucky to have another problem on the adapter
Posted on Mar 11, 2010
My mac laptop suddenly won't recognize it
you may need to swap the usb port it's plugged in
Jun 11, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My lacie hard disk 1tb all of a sudden isnt
Just contact www.lacie.com great support. their answer for my drive was to reboot the drive. For me it worked.
Follow the procedure below to reset the Network Space to factory defaults:
  1. Move the power switch to the OFF position. Wait for the drive to shut down.
  2. Turn ON the drive.
  3. Within about 3 seconds, flip the switch OFF and On several times.
  4. Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both admin.)
Jan 27, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 1 TB Won't Load Up
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Jun 05, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie hard drive won't turn on
My 1TB Lacie suddenly won't power up (no sound, no blue light). It turned out that I might have worn out the on/off switch over the seldom-use 4 years of usage. I push and flip the switch multiple times, and the Lacie came back to live and mount normally. I will just leave it at the On setting and simply pull the power cord when i want to switch it off.
Obviously, Lacie failed to do QA on the on/off switch because my 4 years usage did not totalled to more than 10 on/off per month.
Mar 09, 2009 | LaCie (301074) 80 GB Hard Drive
Hello, I have a Lacie 330770 250 GB hard drive.  It does not respond when I plug it into the outlet.  I have tried several different outlets in different rooms, and neither the green light on the power...
If the green light on your LaCie power supply does not light, you likely have a bad power supply. You can buy a new one from LaCie. If you are purchasing a new power supply from LaCie ask for the higher wattage unit. LaCie upgraded this a while back.
Jan 26, 2009 | LaCie (300770) 250 GB Hard Drive
LaCie drive won't turn on (blue light doesn't go on)
I doubt your hard drive is dead, even if your HD was dead the blue light would go one. It has to be the internal controller.. Your best bet is to get a HD enclosure and put your old drive in there. I've burned through 3 Lacie cases, all with similar problems..
Ciza
Sep 27, 2008 | LaCie (300770) 250 GB Hard Drive
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
LaCie Hard Drive
The hard drive has it's own power supply. If you look on the back of the external hard drive, there is a power button there to turn it off. It doesn't shut off just cause you disconnect it from the PC or turn the PC off.
Feb 01, 2007 | LaCie (300951U) 500 GB Hard Drive
Computers & Internet Logo
16 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
