Question about Casio Exilim Zoom EX-Z80 Digital Camera
My camera memory card is not working - Casio Exilim Zoom EX-Z80 Digital Camera
Sony cybershot H-55 shows 'NO MEMORY CARD' message
The sony cameras are very picky on memory cards. They only work with the some types memory stick duo. But if the card already did work in your camera, you should check the contacts on both the memory stick and in the camera. You also need to check if you did not try to put it in the wrong way around. It should not be possible to reverse the memory stick, but if you don;t know your own strength damage on the memory stick and camera can be done.
Please if possible try to read the memory stick in the card reader on your PC. and look if you did not damage the contacts on the stick and in the camera.
Jan 06, 2014 | Sony Cameras
How do u fix the camera that keeps saying locked card and its not the memory card
Not sure why you are saying it's not the memory card or is it because you are working on the camera internal memory? If so the camera internal memory still needs to be formatted or initialized to properly work with the camera. I'm going to include two diagrams on a memory card that your camera will use first is the Card Lock. This is an actual lock on the side of the memory card and if in the incorrect orientation will prevent formatting all new card must be formatted to the camera they are being used in. You can't format the card in the computer and expect it to work in the camera it won't happen. You can't format the card in one camera and place it in another even the same make and model and expect to work.
Here is the first picture/diagram of the card lock
The second diagram is right out of your owners manual showing how to format/initialize your memory card
Format card was taken from page 89 of your manual Have fun with your camera
Dec 30, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
The camera will only work witha 1GB memory card, we have tried to install a 5GB memory card and the camera shows "memory card error" yet when we try to install the same memory card in another...
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible. Anything over 2GB is SDHC.
Nov 25, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
I get a "Memory card error" message on my SD750?what could be the problem with my card and can it be solved?
The reason there is an error message on your memory card is because the memory card might have been damaged or probably not inserted properly.
To find out if the memory card is damaged, try to use the memory card in other devices that supports the memory card to see if it works. If it works on other devices, then the problem if from the card reader that is in the camera, and if it does not work, then the memory card is faulty. And the only solution is to replace the memory card.
To test the slot in the camera, try a tested okay memory card on it, if it does not work then the slot is faulty and to solve this problem, i will strongly advice you take the camera to a camera repair guy to clean the slot for you.
Goodluck
Sep 13, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
I just bought a new memory card-4 gb SD-K046. It says that the memory card is full but it is not. I have only used this memory card to scan pictures. I uploaded these pictures onto my camera and deleted...
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only
All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB
All other V-Series Cameras: SD memory cards up to 2 GB
EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB
All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB
FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB
EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
reference: http://www.kodak.com/global/mul/service/index.html?reqURL=http://support.en.kodak.com/app/home/src/gosupport
http://support.en.kodak.com/app/answers/list/p/2/selected/true
Phone Number for Kodak is:
800-235-6325
or try get human below for more info on support:
http://gethuman.com/phone-number/Kodak/
Jun 11, 2010 | Computers & Internet
Card error
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
May 06, 2010 | Olympus E-1 Digital Camera
My new sandisk sdhc memory card with 4gb will not work with my camera it says that the memory card is full does this card not work with my camera?
The SD card is not supported by your camera model: Your camera Memory card support is SD/MMC up to 1 Gigabyte.
Please use the supported Memory card and the issue should be resolved
Dec 15, 2009 | Kodak EasyShare C330 Digital Camera
Memory Card
make sure that the memory card you bought is a secure digital (SD) memory card. the kodak memory you have might not be an SD card.
Aug 25, 2008 | Vivitar ViviCam 3785 Digital Camera
Camera wont work when memory card is inserted
I suggest you try to use a different memory card. If it doesn't happen again then it's probably a bad memory card.
Mar 06, 2007 | HP Photosmart M417 Digital Camera
Cards not working with camera
If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Casio Exilim Zoom EX-Z80 Digital Camera Logo
20 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
