Question about Toshiba Satellite 5005-S504 Notebook
How to get icons on your startup screen - Toshiba Satellite 5005-S504 Notebook
Video issue macbookpro 2006
startup and regular sound White screen appears but no apple logo appear ,
1) smc have been reset multiple times. possible motherboard video hardware issue cause over heating.
2) hold option key switch on laptop it will be see hard disk or DVD drive (apple disk inside) icon, the motherboard good if icon appeared. and the motherboard video dead if not appear. hope to help a little
Jan 02, 2014 | Apple MacBook Pro with 17" Display
I haVe a Acer aspire one with a black screen on startup
first I would try the screen cable you have to open the front of the screen take of the bezel check behind the screen happened to my last week
Dec 28, 2012 | Acer ASPIRE ONE ZG5 COMPATIBLE LAPTOP LCD...
My computer is on and has a blank page and it will not let me get to startup
What do you mean blank page? And what is startup? Is startup the desktop with your icons? Tell exactly what happens and what you see when you power on the computer.
Maybe you are saying your system booted up all the way except your screen is blank. If so try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 20, 2012 | Dell Latitude C510 Notebook
Toshiba equium laptop - have lost all icons on startup screen
Try this...turn on the computer, let it get to your windows screen. Then go to Help and Support (on the Startup button), then go to System Restore. Restore your system to any earlier date, that's the easiest fix. Otherwise, I don't know any easy way to fix that.
Mar 19, 2010 | Toshiba Equium 7100S PC Desktop
Icons and start upmenu bar absent
explorer.exe is what displays the icons and the startup bar on the screen so try opening explorer.exe from the task manager. Or if it is already running close it and then reopen it.
Jun 08, 2009 | Computers & Internet
Eee Pc 701SD/linux. No icons appear at startup, just blue screen
Try opening a terminal (Ctrl+Alt+t) and type the following:
sh startsimple.sh
and press enter. It worked for me, hope it will for you!
Jun 07, 2009 | Asus Eee 701Sd Notebook
My cumpaq laptop is powred on . The screen is on but no icons
before windows loads up...
hold F8 key.. will show menu for windows
select safe mode
once in safe mode if icons show up.. restart and let it
load as normal.
If no icons in safe modeyou will have to do a restore from
windows.. what version is it?
if icons in safe mode but no icons in normal windows then
you have something in startup causing the problem
we can check this from registry or msconfig..
keep me posted
May 21, 2009 | Star Logic 17" LCD Monitor
It takes my PC a very long time to boot up, what can i do?
If you have installed any softwares recently it might slow down the pc as many softwares will install a startup file in order to start faster. You can shut these programs from starting up when the pc starts.
I put 2 steps to resolve this in order of simplicity.
Remove icons from the Startup folder
Some programs open with a shortcut icon in the startup folder (Startup icons). Use the following steps to show any startup icons that might be hidden and remove startup icons from the startup folder:
NOTE: Removing items from the Startup folder does not uninstall the software program.
1. Right-click the Start button, and click Explore . The Windows Explorer window displays with Start Menu already selected.
2. Click the plus sign ( + ) next to Programs .
3. Click Startup . The shortcut icons are listed in the right pane of the window.
4. To show any hidden icons, click Tools , click Folder Options , and click the View tab.
5. Click Show hidden files and folders (Windows XP/ME) or Show all files (Windows 98), and click OK .
6. Click an unwanted startup item in the right pane of the window and drag it to a blank area on the Windows desktop. Release the mouse button to drop the icon onto the desktop.
7. Continue dragging unwanted icons until all unwanted startup icons are on the desktop. Click Yes to any window that display asking to confirm the removal of a read-only file.
8. Close Windows Explorer and restart the computer for the changes to take effect. Delete the startup icons that were moved to the desktop after you are satisfied with the way the software programs are working.
If you find that a particular software program should not have been removed from the Startup folder, double-click the startup menu item to open the Startup window. Then drag the icon from the desktop back into the Startup window.
Jan 11, 2009 | Compaq Presario 5000 PC Desktop
Comp freezes on startup
need more information on your problem could be several broblems
Dec 13, 2008 | Dell Vostro 1700 Notebook
Acer
The problem is with some programs on startup
To fix it follow instrucions:
Go start run then type MSCONFIG +startup AND DESABLE ALL PROGRAMS ( just don't desable antivirus)
Let me know if you got help and please rate me as FIXYA!
Jan 05, 2008 | Acer Aspire 3000 Notebook
Toshiba Satellite 5005-S504 Notebook Logo
15 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
