Question about SanDisk Sansa m230 MP3 Player
Can't Write/Delete/format I'm having Sandiskcruzer micro 1Gb thumb drive. Now I'll not able to write/detele files to that. I tryed format it but its not working. Files are also not in Readonly mode. Error is "Cannot Delete File.txt: cannot find specified file / make sure you specify the correct path and file name" Please let me knw solution for this. Thx Sanjaya
  • 8,596 Answers
Make sure the lock is not engaged
Posted on May 26, 2008
SOURCE:
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
Micro sd 2gb tidak bisa format
Hallo scorpio, semoga solusi ini membantu
If the micro SD format fails, do not you repeat the formatting process. Because it will exacerbate the damage to the micro SD. Follow the steps below. Good luck.
Step One:
Step Two:
If the second solution does not work, it means your micro SD damaged firmware. Based on experience, one of the causes of damage to the firmware is, the formatting process is done repeatedly, but always failed.
Can't format a flash (thumb USB) Drive on my MacBook Pro. Image (pictures) Data is still there, but many music files are corrupt. Can't delete the files and wipe the thumb drive clean, returning it...
Download Partition Wizard for mac bootable version and burn it to a dvd. Now, put the dvd in and turn off the computer, now put the usb drive in. Start the computer and boot from dvd drive Partition Wizard will boot up, left click on the usb drive and of the left side click format, now up top left click apply. Wait until it's done, now your usb drive is blank.
Oct 17, 2017 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How do I create more space on a sandisc 16GB USB
To create more space, you can delete the files that are on the drive. If you are not concerned with any of the files that are already on the drive, you can right click on it in My Computer and select format. From that window, check "quick format" and then hit format. That will completely wipe the drive and you should have most of the 16GB free.
Jul 20, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I cannot format my transcend micro sd 1gb card nor can i add new data on it
it means that the memory card's sector is damaged by a virus infection...try to delete the files while in the mobile and then format it..if it agains appear the same then you've to buy a new card only`
Jul 05, 2009 | Transcend (589307) Media
Cant format my micro sd card
Write Protected
When I try to delete the files Kingmax 1GB Micro SD Memory Card it says that The disk is write protected or insert other disk
Oct 29, 2008 | Kingston 1GB Secure Digital Memory Card
Problem regarding the write protection of pendrive
go onto this website and download the formatting software: http://www.apacer.com/en/products/Handy_Steno_HA202_downloads.htm
I had the same problem with an old 64MB jump drive. I did some hunting around on HWA as well as Googling other forums. The general agreement seemed to be that the drive was simply dead. I tried changing all the permissions, attrib in CMD, and even logging into Linux as "root" (the equivilent of Microsoft's "Administrator") to no avail. I was able to back the files up to another drive, and they regained their permission settings, but from what I read, the drive was simply dead.
Aug 05, 2008 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
SanDisk Sansa m230 MP3 Player Logo
63 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
