Question about Frigidaire FAH106N1 Wall/Window Air Conditioner
Condensor? There was a build up of water in the tray and I heard the fan in the back going through it. I had to drill a hole to drain the water because there was not one. It is know much quieter and running better except that the condensor or motor does not kick in even when set to 60 degrees. I waited the 3 minutes still nothing. It just runs in fan mode even when on cool.
    Novelist:
  • 75 Answers
It probably shut off on high pressure. Let it cool down, plug your hole that you drilled and give it another try. The water is suppose to collect there and the fan is suppose to throw it into the condenser to keep it cooler and make it run more efficiently. Good Luck,
kstfas
Posted on Oct 10, 2007
  • Anonymous Oct 10, 2007
    P.S. The drilled hole dosn't have to be completely water proof and will not be under any pressure so a piece of putty or silicone, whatever will be good enough to plug it with. It does need that water though to keep from getting too hot. The compressor has a High Temp shut off and will probably be shut off for a few hours after it reaches that temp. I don't believe the unit has been damaged. Please keep in touch and let me know.
    Thanks,
    kstfas
SOURCE:
I have a 6000 btu window unit. I was wanting to know how the unit drains the water. where does the water come out of the unit at? I could not find a drain hole.
No drain holes on most units that size
The water gets from the front evaporator thru
a small hole you can not see
Then it finds it's way to the outside or back on the
bottom metal pan
It is evaporated by the condensor fan
It may drain out over the rear pan lip, if
it gets alot, but no drain hole is necessary
You can angle the unit down at the outside or
rear & you can drill a small hole, but it uses the water
to cool the condenser
Aug 04, 2011 | Haier HWR08XC7 Air Conditioner
Window A/C - no apparent drain holes for the condensate tray ?
On most new units, the water left in the tray is picked
up by the fan motor blade which kind of cools the unit down.
On some models there is a round hole on the bottom left hand corner on the back of the unit. Really hard to
get a fitting between condensor coil and frame,but it
can be done. However the manufactuer will usually state if a drain has to be run if it is needed
Jun 29, 2010 | Samsung AW1803M Air Conditioner
I have an Admiral GS20B6D3EV fridge freezer and am getting a slow intermittent trickle of water from the freezer which is also forming a lot of ice in the bottom of the compartment. Assume it is due to the...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Sep 07, 2009 | Admiral 26 cu. ft. Side-By-Side...
Condensation leaks out front of unit into the house.
Hi, no don't drill holes in bottom tray, to make drain, that's design, you need to keep water there, the fan usually pick up water(moisture) and add to your air inside your home, otherwise the air in your home will become to dry, dry air will create static electricity all over your home, from your carpet to your clothes, you need to level your unit horizontally, put a spirit level, and you should have a slight pitch, from front to back, good luck.
Aug 03, 2009 | Maytag M6Q10F2A Air Conditioner
Water draining into frig
you have a blockage in the drain tube, remove panel back of freezer..you will see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. the reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck!
Jul 06, 2009 | GE GTS22KBP Top Freezer Refrigerator
ICE BUILD UP ON THE BOTTOM OF MY FREEZER BELOW THE LAST TRAY
clear ice and with hot water pour into the drain hole till open and drains ,, take back panel of freezer out and wrap a piece of thick cooper wire around the heater and drop into the drain hold about 1in and it will keep drain open / thanks
Jan 14, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Split Unit Spitting water
Do you live in an area of high humidity? This could be your problem. The water that is coming off the evaporator and draining to the outside pan is building up and picked up by the condensor fan and consequently blown by the fan inside. If this is the problem the fix is to drill a hole in the pan to permit the water to drain from the pan. Be careful as to where the hole is drilled so as to not damage any component of the a/c. I would suggest at least a 1/4 inch drill bit be used to make the hole.
May 26, 2008 | Friedrich QuietMaster RS10J10 Air...
Leak repair Samsung window air conditioner
Modern window units intentionally do not allow the water to drain directly, they want the fan blade to sling the water on to the condensor (the coil that is outside) to aid in cooling actually helps the unit cool better in high outside temps, it also evaporates it this way, depending on where the hole was drilled it may be able to be repaired, if it was just a copper tube it will be less expensive than replacing the whole coil. Since its a relative inexpensive unit anyway the labor and freon may be more than its worth. Lesson learned dont drill a hole in the base it lowers it's efficiency and can lead to a punctured freon line.
Sep 29, 2007 | Heating & Cooling
Water dosent drain
well lets work with it becouse that the one you have..first let me tell you dont make that hole becouse the water that remaing in the tray is use to cool down the condenser and beleve me its a good idea..its not supouse to condese more water thant he can evaporate..but try to screw a littel bit more the two screw in the back of the cabinet to down the cabinet 10 degrees more to see if that help you...good luck
Aug 03, 2006 | Haier HWF05XC5 Air Conditioner
Frigidaire FAH106N1 Wall/Window Air Conditioner Logo
99 people viewed this question
Top Frigidaire Heating & Cooling Experts
Donni Steen
Bill Long
Pete Norton
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
