Question about Carrier Heating & Cooling
Carrier weathermaker furnace problems - Carrier Heating & Cooling
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
What is going on whats it not doing
Posted on Sep 20, 2017
SOURCE: carrier furnace weathermaker 8000
. Several times of recyling power normally brings the furnance up. Though the failure code has always been 31, there are several different behaviour when the blower starts after reset :
a. blower simply creases.
b. there is an attempt to start the heating unit (I hear the high pitch noises), then everything stops.
c. there is an attempt to start the heating unit (I hear the high pitch noises), once I see the orange glow from the coil, normally the gas is lit up and the unit starts working.
Posted on Dec 18, 2007
  • 86 Answers
SOURCE: Carrier Weathermaker gas 8000 will not ignite
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Posted on Mar 28, 2008
Master_Tech
  • 770 Answers
SOURCE: I have a carrier weathermaker
most likely you will need to pull the coil to clean the drain pan area around the coil
Posted on Jul 09, 2008
  • 124 Answers
SOURCE: I have a Carrier Weathermaker
you can disconnect the wire attached to w2 on the new stat and that way the stat will be unable to turn on the furnace when you push it more than two degrees above the room temp. if you leave the wire connected to w2 then anytime the stats desired temp is set more than two degrees warmer than the house, the heat pump and the furnace are designed to come on together till the temp approaches two degrees of set point then the furnace shuts down and the pump maintains. this way the pump will do its thing till it gets cold. (below 40 degrees). when that happens you can go to the stat and switch to emergency heat. this will power up only the furnace as soon as there is a first stage call for heat. it will not wait to see what the pump is doing and go to heating with furnace right away. you simply switch back to normal heat setting when temps go back above 40 degrees. the furnace is actually wired to two terminals on the stat. w2 is backup heat terminal you disconnect and the x terminal or aux terminal is energized only when you are switched into emergency heat.
Posted on Nov 10, 2008
wbwill
  • 68 Answers
SOURCE: Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Posted on Nov 22, 2008
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 58TUA doesn't work
The switch could be defective but more likely the furnace blower is failing.
Dec 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a carrier 58RAV050-12 and my furnace won't turn on. It was working earlier today but it just stopped. Any suggestions as to why?
Check the pilot lt. If its out shutdown your furnace and call a repairman. If the pilot light is on, the flame sensor might have gone out. It's a long silver sensor that sits in the pilot light flame and senses when the flame is present. If it isn't working the furnace will automatically shut down.
Nov 04, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Furnace overload limit switch
Here is the service manual with wiring diagram.
Dec 19, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Extreme heating bills
easy way to fine the high usage is to turn everything off and watch your meter and have someone start turning thing back on and watch for the most usage of power
Jan 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Oct 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
41 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
