Question about JVC SP-PW100 Subwoofer
Can one connect powered speakers to a reciver
Connect an AUX cable
Use the speaker output and plug it into the mic socket. Not ideal but the alternative is to buy a cheap adaptor for the end of the aux cable so that you can plug your speaker output into the aux input.
Nov 22, 2013 | Pioneer VSX-1014 Receiver
My problem is that when turn the volume up so high it flashes over load and shuts off and the fan on the back of the reciver constly runs is the fan susposed to blow in the reciver or out of the reciver...
Fans usually blow in the direction that would assist warm air to exit the device. Since heated air rises and there are vents on top I would guess air would be drawn in.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Aug 14, 2011 | Technics SA-DX940
Yamaha RX-797 shuts down when playing at low volume while increasing the volume. If you lower the input wolume from the source into the reciver you can increase the volume on the reciver but when you reach...
That would be consistent with reaching an overload threshold on the amplifier's outputs.
This is mostly boilerplate but it may lead you to the problem...
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 20, 2011 | Yamaha RX-797 Receiver
I cant auto tune my yamaha rx v 365 reciver because i get an error saying that i dont have my speakers connected even though i know they are and working just fine.
1.Check you select the good set of speakers according to the connections you made at speakers output.
2.Have the soldering of your power output IC module remaked (by a technician only).
Spider Guy
Mar 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I get a protected message in my reciver str dh 500 reciver
THE GOAL HEAR IS TO DETERMINE IF THE INSTALLATION IS CAUSING YOUR PROTECTION FAULT OR IS IT THE RECEIVER ITSELF HAVING INTERNAL DAMAGE. REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION, THEN THE RECEIVER WILL NEED TO BE SERVICED, AS YOU HAVE TOTALLY SIMULATED A BENCHED CONDITION THAT IS TOTALLY INDEPENDENT OF YOUR INSTALLATION. MOST TIMES, THE RECEIVE WILL GO INTO PROTECTION WHEN IT SEES AN EXCESSIVE LOAD WHEN TURNING UP THE VOLUME, WHICH IS USUALLY CAUSED BY TOO MANY SPEAKERS OR DAMAGED SPEAKERS, BUT IF NO SPEAKERS CONNECTED, THEN IT IS USUALLY BECAUSE THE RECEIVER SEE AN EXCESSIVE LOAD DUE TO ITS OUTPUT SECTION BEING DAMAGED. IN ANY CASE, ONCE REPAIRED, YOU MUST CHECK YOUR SPEAKERS FOR BURNED VOICE-COILS, WHICH WILL IMPOSE AN EXCESSIVE LOAD TO THE AMPLIFIER AND CAN CAUSE IT TO FAIL AGAIN. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 14, 2010 | Sony STR-DE475 Receiver
Can i hook up the bose wireless reciver for the rear speakers with a onkyo reciver
I don't see why not. Use any record out or if you can rear pre amp out connect to the input on the bose unit.
Oct 09, 2009 | Bose Acoustimass 16 Speaker
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
I install wire from the battery to the amp ground the amp then i installed the audio jack from the reciver to amp an then the speaker wire an nothin
Power amps must be connected + battery wire to the amp +b terminal with a gauge 8 or bigger depending on the power rating, - ground to the car chassis as short as possible,connect cords from head unit to power amp with good groundings, and remember to connect the speakers and the remote trigger from head unit to turn the amp on.
Aug 27, 2009 | Performance Teknique ICBM-772 Car Audio...
Want speakers to work when watching tv
you have to find the audio output from tv, or tv box, and hook it to an input on your reciver, then you will have to change input on the reciver to the input you pluged the audio cables into, that will fix your problem
Jan 11, 2009 | RCA RTD258 System
Problem adding wsp155 wireless speakers.
You must check with the instalation gude for the wireless speaker to see if the connection to the reciver is a high impedence or low impedence... If its like most wireless set-ups its going to be a high impedence output from the reciver to the transmitter part of the speakers. That would be from the RCA jacks in the back of the reciver maked line out or tape out. If you want to use them for a specific speaker output , some recivers have an output jack that would be labeled center sperker out but would be an RCA type jack ect ect. If your reciver dosent have that you can in a higher end audio store get an adaptor to convert the speaker output to a high impedence, But I dont recomend that as some of the adaptors do cause excessive strain on the output section of the amp or reciver.. If you buy a good one though you should be fine.. You get what you pay for.. Good Luck
Aug 06, 2006 | RCA WSP150 Main / Stereo Speaker
JVC SP-PW100 Subwoofer Logo
24 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
