Question about HP F4480 All-In-One Printer
Noise loud gears clicking - HP F4480 All-In-One Printer
  • 33 Answers
Hi , clean printer's paper Feeder assembly or chnage..
Posted on Nov 24, 2013
My Kitchenaid mdl: KSM 155gbca is making a loud bumping noise with or without an attachment.
It is more than likely in the planetary or the fuse gear inside the gear box. Try it once you have the planetary off before you go looking inside the gear box. Easiest is planetary problem but far far more likely is the fuse gear.
Aug 08, 2014 | KitchenAid Artisan Series Tilt-Head Stand...
1995 GMC SONOMA makes a loud sqeaking noise when i take off in the first to third gear, after third gear it stops, but when i get to a stop sighn it starts all back over, loud noise.
This type of noise is likely to be a universal joint that is worn out in the drive line. have a shop put it on a lift and inspect the joints.
Jun 06, 2012 | 1995 GMC Sonoma
Printer making a loud clicking noise when printing.
the feed roller gear is stripping; remove the cover and, adjust the gear retainer before it completely fails. (it should be easy to see the gear once the printer cover is removed.
Mar 30, 2010 | Dell 1700n Laser Printer
04 toyota corlla 5 speed
If there is only one click when you go into first or reverse. Then look at the linkage on the clutch pedal. If you push the clutch pedal down and up (without putting it into gear) does it still make the click sound? Is the transmission going into gear normal? Is the throw-out bearing making any noise? A throw-out bearing can make a loud click noise.
Jun 18, 2009 | 2004 Toyota Corolla
Clicking noise
the clicking noise is the gear fro the paper feeding roller. seems that the gear is broken, need to have it replaced.
May 21, 2008 | Brother MFC 8500 All-In-One Laser Printer
Samsung 3160fn all in one printer. making loud clicking noise when printing
Here's what I posted in regards to my CLP 300 which had the same problem. Might be the same thing??...
Mine did this after I replaced a toner cartridge (the round ones). Here's what causes the loud clicking:
Some (most?) replacement ink cartridges have a little square chip -- like a mini circuit board -- on them which gives the printer information about how full they are. This is located on the insertion end, right next to the round black thing with the little gears on it.
For the cartridge to go in all the way, and allow the gears to properly "seat," the square "circuit board" needs to "float" just a little on the spongy thing it's attached to. So when you push the cartridge in FIRMLY, the gears seat, and the "circuit board" will end up getting pushed in about 1/16 of an inch.
I think what happens in some cases (at least with mine) is some cheap replacement cartridges don't let the "circuit board" push in at all, which means the gears don't quite seat properly, and, as they are trying to connect on the printer's gear receivers, they are constantly connecting and disconnecting, causing that loud clicking noise.
On one cartridge just pushing in the "circuit board" really hard freed it up and allowed it to "float" (be pushed in little when the cartridge was then inserted). In another case, I ended up getting a butterknife and prying off the circuit board (breaking the plastic or glue seal that was holding it) then setting back in, on top of the little spongy sticky thing it's supposed to float on.
In both cases, the cartridges were then able to go in all the way, and the clicking noise stopped.
Hope this helps!
May 05, 2008 | Samsung CLP 300 Laser Printer
HP F4480 All-In-One Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
