Tripping the electrics
SOURCE: Our beko frost free fridge
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
SOURCE: my mothers beko fridge freezer making bubbling sound
Sounds like the evaporator fan is doing its job. Nothing to worry about. Good hearing is a blessing all fridges make different sounds some click loud while others gurgle loud. Some pop and snap. Till I got my hearing aids I didn't know mine ran so loud and clicked.
SOURCE: hi, my fridge freezer keeps
Try this:
Turn your thermostat as warm as it will go, you are trying to isolate the compressor and keep it from turning on. If your fridge has an "off" position, then turn it off. Reset breaker, plug refrigerator back into the outlet. If the fridge trips while "off", then you are likely looking at a damaged cord / wiring.
If the breaker doesn't trip, unplug the fridge, and move the thermostat to the warmest position possible. Plug fridge back in, If the breaker holds, then you are on right track. Slowly move the thermostat to a cooler setting. You want to just reach the point where the compressor tries to start. If breaker holds here, then you are in good shape so far. It indicates a problem with the defrost heater (if equipped), or the ice maker (if equipped). If the breaker trips as soon as the compressor tries to start, your compressor may be damaged (bad and expensive).
This article refers to BEKO Fridge Freezers:
According to
the London METRO magazine ( http://www.metro.co.uk/news/868330-beko-fridge-freezers-fire-risk-warning-issued-to-homeowners-amid-recall
) The MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
From what I
can ascertain, the fridges affected were manufactured between January 2000 and
October 2006
If you go to
the BEKO website, there is a link to check your serial number:
https://refsafety.beko.co.uk/
But I have
to say, matching serial number or not, if I had an affected model, I would be
checking with BEKO anyway!!
