Solution to SC390 error code on Richo infotec 4182mf copier
drichards
  • 87 Answers
SOURCE: Infotec IS 2220D Copier (same as aficio 1022 i think) SC551 Error
Start by pressing clear modes, 1, 0, 7, and press and hold clear/stop. enter copy sp, select 7 fot data log, scroll to 7807, and execute. exit all the way out, and recycle the power. See if that does not fix your problem.
Posted on Apr 01, 2008
SOURCE: Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
Posted on Sep 19, 2008
  • 24 Answers
SOURCE: code 541
SC 541 is a fixing unit error, clean the thermistor and then reset the code by pressing clear(yellow) then 107 and hold stop(red) key for 5 to 10 seconds then the display change. now turn off the machine from main switch, wait for five second and then turn on the machine.
this will reset the SC541. in case if the problem exist change your thermistor and check the thermostat.
Posted on Oct 12, 2008
SOURCE: error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Posted on Nov 10, 2008
  • 990 Answers
SOURCE: funcional problem code SC542
Hello sir; Follow the steps to reset;
1, press "clear mode", "107", then press and hold "clear/stop" key untill display change.
2, enter 5810, then press "execute" on screen, then press "close".
3, turn power off then back on, it will go back to normal.
Posted on Apr 28, 2009
My copier machine comes up with functional error code sc672. can anyone help
That error code appears to indicate 'Op panel to controller problem' see here http://multifunctionalcopier.blogspot.co.uk/2012/06/ricoh-error-code-list.html
Sep 05, 2015 | Ricoh Richo KR-5 with 35-70mm f3.5-4.5...
SC551 error on Infotec IS2220D same as aficio 2020D
it must be a small damage in capacitors in power supply
Mar 25, 2008 | Ricoh Aficio 2020D Copier
Error message sc390
SC390: TD sensor error
-Definition- [B]
The TD sensor outputs less than 0.5V or more than 4.0V 10 times consecutively
during copying.
- Possible causes -
· TD sensor abnormal
· Poor connection of the PCU
Jul 07, 2011 | Ricoh Office Equipment & Supplies
Error code sc320 showing on infotec 4151mf
That is a polygon motor error.
This motor is from the Laser Unit. Probably you have to change it.
If you do not have technical training i advise you to call your provider.
Mar 11, 2011 | Ricoh Aficio 250 Copier
Sc390
SC390 = Toner Density Sensor abormality
Possible causes:
  • Poor concentration of developer
  • Toner density sensor faulty
Are the prints/copies coming out ok? If the copies are very faint or heavily overtoned then changing the developer may cure the error code. If the copies look OK then you probably need to get the toner density sensor replaced by an engineer.
Hope this helps.
Feb 10, 2011 | Ricoh Aficio 450 Copier
Sc390
- Possible causes -
Dec 30, 2010 | Ricoh Aficio MP 1600L Black and White...
The copier warms up and comes up with an error code of sc173
please precise which is the brand and model
by the code it seems to be a ricoh,nashuatec,lanier,infotec,rex-rotary,gestetner
but you have to specify the model
Mar 19, 2009 | Office Equipment & Supplies
Error code sc 541
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Solve my problum
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Mar 25, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
57 people viewed this question
k24674
jasbo
jasbo
