Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
1h (?) signal, and soap dispenser doesn't open
I have a 2-year-old GE Profile PDW8800 dishwasher that shows a 1h (or something like that - maybe Ih?) signal on the timer display no matter what cycle button I press. When it runs (IF it runs), the soap dispenser doesn't open and the dishes are not clean. This is a new problem, but this dishwasher has already been repaired 3 or 4 times for other problems in the two years we've had it.
  • Anonymous Dec 19, 2007
    IH shows no matter what I do. My dishwasher is only 7 months old.
  • 35 Answers
The part called a Wax Motor (about 2 inches) inside the door is responsible for opening your dispenser.Check it / replace it.
Posted on Dec 09, 2007
6ya staff
SOURCE:
A GE dishwasher GDT580 that's displaying code 1H or IH and will not start
that's not an error code. it's a 1H, as in one hour, the delayed start function. hold the delay start button down to override, then reset it back to where you want it.
Aug 27, 2015 | GE GDT580SSFSS 24" Stainless Steel...
Ge Profile soap dispenser doen't fully open during wash
Pour boiling water into the dispenser, it may be gunked up with soap residue
Mar 21, 2017 | Dishwashers
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
GE Profile Smart Dispense is clogged. How can I unclog it.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Mar 20, 2011 | Dishwashers
The soap is not coming out of the auto dispenser hole and it is full and has been
Hi
Daniel
Feb 14, 2011 | GE Profile PDW8480JSS Built-in Dishwasher
Husband mis filled ge profile washer dispeser. can we use mixed solution or should we throw it out
Did he overfill the soap dispenser with extra automatic dishwasher soap or with something else? If it is just automatic dishwashing soap then maybe run the cycle with no dishes in it on heavy wash. Now if he filled it with regular dishwashing soap clean out as much of it as you can then run the washer without dishes. If you leave regular soap in there your kitchen will be filled with bubbles.
Sep 13, 2009 | Washing Machines
GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dear friend,
ngfam at you service! happy to assist!
Sprayers or sprayer clogged and or pump weak!
Better call service
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 04, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
1,396 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Vitally Alcher
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
