Question about ASUS M2N68-AM SE2 Motherboard
How to clear cmos on asus motherboard - ASUS M2N68-AM SE2 Motherboard
5 Suggested Answers
s_4u_11
  • 535 Answers
SOURCE: how to clear CMOS on Asus P4B533-VM motherboard
u have to remove bois battry for the few mints or u have to reset jumper from the moter bord65ab895.jpg
Posted on Jan 16, 2009
  • 250 Answers
SOURCE: i have asus m2n 68 se2 motherboard and amd
Before anything you should suspect the power supply. It may be able to start the board for a second, but doesn't have the oomph to keep it running.
Posted on Aug 09, 2010
  • 252 Answers
SOURCE: Hi, I just swapped out
Make sure you didn't plug the USB connector for the ports into the Firewire connector on the motherboard.
Posted on May 20, 2011
bayyagg
  • 1672 Answers
SOURCE: I flashed the bios on my Asus motherboard M2N-E, and then replaced the processor with a quad. Cleared the cmos and now the computer won't post? What do I need to do to get it up and running again?
Try to put back the old procie, if it runs again that means the new procie is not compatible with board.
Read the manual for the compatibilty issue for your MoBo.
Tell me if it works.
Posted on Nov 19, 2011
Nov 17, 2011 | ASUS M2N-E SLi Motherboard
Save not cmos on mainboard asus p4p800s-x chek batry&clear cmos but not resolv save not cmose
ASUS CrashFree BIOS2
The CrashFree BIOS 2 feature now includes the BIOS auto-recovery function in a support CD.
Users can reboot their system through the support CD when a bootable disk is not available, and go through the simple BIOS auto-recovery process. ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional R
C.P.R.(CPU Parameter Recall)
When the system hangs due to overclocking failure, there is no need to open the case to clear CMOS data. Just simply restart the system, the BIOS would show the previous setting and then users can amend the CPU setting again.
ASUS EZ Flash
With ASUS EZ Flash, you can update BIOS before entering operating system. No more DOS-based flash utility and bootable diskette required.
hope this helps you
Mar 03, 2011 | ASUS P4P800S-X (610839118175) Motherboard
How to clear cmos in asus a7n266 mb
I had similar mobo and this is what the Asus technician told me. Take out the round battery in your motherboard and flip it around and put it back into the battery slot.(it sounds weird but that is what he said) Hold it there for 20seconds and then put back in the right way it was.
Your cmos should be cleared now. Make sure your pc is switched off when doing this.
Feb 08, 2011 | ASUS NVIDIA nForce Chipset A7N266-VM...
How to remove restricted access
Reset the CMOS (BIOS memory).
You do that and it will remove and BIOS passwords.
It will tell how to "clear CMOS" in the motherboard manual.
Or you can try unplugging the computer, and removing the little CMOS button cell battery for a few minutes.
Note if you do clear it, you'll probably have to set a few BIOS settings from the defaults.
Jul 01, 2010 | ASUS M2N-MX Motherboard
I removed and replaced the 5v jumpers on an Asus p4p800 mb and now USB is hosed. Should I clear the cmos?
Yeah, I would, but READ YOUR MANUAL. There are several jumper settings that can be changed. Just be careful and you should be OK. You will have to run thru the BIOS setting if ya clear the CMOS. Default should work unless you have a RAID or something fancy.
Dec 28, 2009 | ASUS P5PE-VM Motherboard
How do i clear the cmos on my asus p5nsli
support.asus
just to clarify, to clear your BIOS, there should be a 3 pin set on your board usually located some where just below your RAM. On the board will be printed something like "CLR" or "CLEAR" move the pin connector, with the power off, from its current position to the middle pin and the open pin. Wait about 15 to 20 seconds and move the connector back to the original position. You have just reset your bios to factory defaults.
Oct 18, 2009 | ASUS P5NSLI (0610839134670) Motherboard
No power detect for asus p4s533
clear cmos in motherborad....jumper is near battery....set jumper at 2-3 pin for 5 seconds....and then return it again at 1-2 pin.....if doesnt work,please remove cmos battery and replace new cmos battery...
Oct 15, 2009 | ASUS P4S533-MX Motherboard
How to clear CMOS on Asus P4B533-VM motherboard
Jan 16, 2009 | ASUS P4B533-VM Motherboard
Need to reset Asus k7v bios
Yes, if you consult your motherboard manual this will show you the location of the cmos battery and reset jumpers. You can either move the jumpers from pins 1+2 to 2+3 and then back again after a few seconds or remove the cmos battery for a few seconds. Make sure your pc is off!
Dec 16, 2008 | ASUS VIA KX133 Chipset K7V (K7V/500/SWA)...
ASUS M2N68-AM SE2 Motherboard Logo
77 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
