Question about TP-LINK TPLink Tp link Tl wr940n 300mbps Wireless N Router
I can't access my TL - WR940N router with the default ip address
    Problem Solver:
  • 24 Answers
Make sure you are on the wireless network when you try to connect, also are you sure you haven't chnaged it during the setup wizard?
Posted on Jul 08, 2014
2 Suggested Answers
SOURCE: i have a TP-LINK TL-WR940N
I have the same problem. Some people says that its because of interference from other neighbors' wireless signals or any other in the surrounding etc.You can go to Router Properties and change the CHANNEL to 6 or 11 and observe any changes.
Posted on Sep 25, 2011
Block website
This is from the TP-Link Website:
http://www.tp-link.com/en/article/?faqid=273
Jun 25, 2014 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
Block website
Just access your router settings, and find filtering websites
Weak signal
You may actually be too close to the device, You can access the wireless router from a browser (192.168.0.1 or tplinklogin.net)
The default login is admin / admin
Once the setup page displays you can go to the wireless section.
Here you can adjust the TX Rate and the Channel Width and other features to fine tune your device to work in your situation.
Here is a link to the manual as well in case the above is not clear.
http://www.tp-link.com/Resources/document/TL-WR940N_V1_UG_111228.pdf
Also ensure the device does not have to go through any metal walls, or other material that may disrupt the signal.
Please comment if more information is required.
Oct 17, 2013 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
No light only power light is on...
First, did you pay the bill? Unplug the IPS modem, remove battery, if applicable, unplug TP Link, shut down computer. Ckeck ALL cables reseat, Replace battery, plug in ISP modem, allow it to selftest, plug in TP Link, allow it to selftest, Reboot computer. If you connect ISP Modem directly to PC and it doesn't ID your IP address use this: http://helpdeskgeek.com/networking/release-and-renew-an-ip-address/ To assist you. If this doesn't work contact your ISP provider . Try another Wireless Access Point. My ISP, Xfinity, drops from time to time , for no appearent reason, due to a number of outside difficulties.
Dec 14, 2012 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
TL-WR940N
Hello
I can give some details on port forwarding for TL-WR940n. You could follow this procedure given below. here is the link too. http://www.tp-link.com/en/article/?id=72
How do I open ports on my TP-LINK wireless Router?
Suitable for: 300Mbps Wireless N Routers, 150Mbps Wireless N Routers, 54Mbps Wireless G Routers
Step 1 Open the web browser and type the IP address of the router (default is 192.168.1.1 or 192.168.0.1) into the address bar and then Press Enter.
Step 2 Type the username and password in the login page, the default username and password both are admin.
Step 3 Click Forwarding->Virtual Servers on the left side, and then click Add New... button.
Step 4 Type the Service port which you want to open and the IP Address of your computer; Select Protocol to TCP, UDP or ALL; Change Status to Enabled
Step 5 Click Save button to save the settings.
Note:
If you want to open port 80 for Web server in your computer, the Management port of the router will be changed to 8080, you need to type Http://192.168.1.1:8080 to connect to you router.
TP-Link_SupportForce
TP-Link USA Corporation
Tel: +1 866-225-8139
E-Mail: steve.crow@tp-link.com
Website: www.tp-link.com/en/support/index.asp
Jun 08, 2012 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
All D-Link Dir configuration done but I can't access internet,why is that?
Reset your router back to it's factory settings by holding the reset button for about 5 seconds.
I have provided a list of the most popular router brands. If it does not work you may need to
google what your specific model's default IP address/default username/default passwords are, for
example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it
can depend on where you obtained your router. If you purchased it yourself from a store then the
standard defaults should work. If you obtained your router from your Internet Provider you may
need to contact your service provider. It also may depend whether it's an old or new model router
as well. And you may need to press and hold the reset button on your router several times before
it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is:
192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or
192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 06, 2011 | D-Link DIR-600 Router
HOW TO UNLOCK MY WIRELESS ROUTER TL-WR740N
You should restore the Factory Defaults to get full access to the router. Be aware that all custom settings will be undone with this procedure.
This can be achieved this way:
* Choose menu "System Tools ? Factory Defaults", and you can restore the configurations of the Router to factory defaults on the following screen
* Click the Restore button to reset all configuration settings to their default values.
* The default User Name: admin
* The default Password: admin
* The default IP Address: 192.168.1.1
Aug 23, 2011 | AGPtek TPLink TLWR740N IEEE 80211bgn...
I have access point TL-WA500G and I can`t open my admin i do reset`t but stell can`t open my admin .
The Issue you are having is that you might be typing in the wrong IP address for the Access Point.
Follow these Steps Below and this should fix your problem.
Step1:Open your web browser.
Step2:Type in IP address http://192.168.1.254 in the address field of web browser and press Enter.
Step3:Enter admin for the User Name and Password (both in lower case letters).
Step4:Then click OK or press Enter.
Go to This web Address to get a copy of the manual for your device in PDF Form.
http://www.tp-link.com/english/soft/TL-WA500G_User_Guide_201003.pdf
Apr 29, 2011 | TP-LINK TL-WA500G 54Mbps Wireless Access...
Trying to set up for first time a TL WR 1043 ND router. Mode 1 : with provided CD Router connected to cable/telephone modem After CD installation and during router configuration verification process the...
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Apr 20, 2011 | TP-LINK TL-WR1043ND Router
I have a TP-LINK TL-WR940N wireless router.and it disconnecting after sometime.I m running it on windows 7.plz tell me the solution.
Jan 02, 2011 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
TP-LINK TPLink Tp link Tl wr940n 300mbps Wireless N Router Logo
107 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
alex metro
alex metro
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
