Question about ASUS WL-330G 802.11g/b (wl330g) Wireless Access Point
Connection problem from time to time my notebook loosing a connectio to 330g. I need to switch off and switch on 330g just to make it wotking. Many customer have reported this problems but ASUS don't give any new firmware. Does anybody know some tricky to fix it? Does anybody try to use 330gE firmware for 330g? many Thanks friends
  • 49 Answers
Firmwares are designed for each particular product. 330gE firmware will be invalid for 330g. Maybe ASUS is coming up with a new one. have you tried checking lately? It is usually published thru the net. If it's already a recognized issue for the product. manufacturer will be posting one in no time.
Posted on Oct 25, 2007
SOURCE:
My jeep wrangler safari cant move the automatic shift out of park
There is a safety switch on the brake pedal and if it fails you cannot move the gear shift lever. Check under the dash on the brake pedal shaft for the switch and make sure it is not loose, disconnected, damaged or failed.
Aug 19, 2016 | 2002 Jeep Wrangler
On a hot day I seem to have a drop in volume fromthe switch to the solanoid and car will not turn over. Does the system wotk through a relay.
Hi Hubert
No. Your problem maybe fixed with a few simple fixes
At the starter clean and tighten all the wire connections
At the battery clean both posts and cable connections back to silver and tighten
Test start
If no start, check ignition switch and key cylinder for proper operation and connections, Follow the wires and look for any problems, loose wire, etc.
Hope this helps let me know Mike!
Jan 29, 2016 | Cars & Trucks
Why does my blower motor wotk on all speeds except high on a 92 s10
you need a blower resister most likely. or the speed control switch. 99 out of a 100 times the resister shot craps
Jul 12, 2012 | Chevrolet S 10 Cars & Trucks
Hello, What is the largest hard drive I can upgrade too for my Biostar 330G? Can I use a SATA and install a IDE hard drive as my slave backup? Thank you. Remi
As I recall, this model has one IDE channel on, which typically powered an optical drive. The manufacturer claims that it supports one IDE drive, in theory, you could set the IDE HDD on the second connector of the IDE cable (secondary slave), however, it may be that the Bios will not recognize this.
My own thoughts would be, as this has 2 SATA ports, to leave the IDE connection alone and for the Optical drive and put another SATA HDD on the other SATA connector.
If you need to use the IDE drive, you can get an IDE to SATA adapter and that would enable you to use it connecetd to the SATA connector
As to capacity, I'd assume it would run any size of HDD
Jun 23, 2011 | Biostar iDEQ 330G (IDEQ330G) Barebone
Wont turn on asus wireless ap wl-330g
check the power adapter may be thats gone faulty
Jan 16, 2010 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Laptop networking problems
if you have with your unit please againg connect to the internet if same problem occur...
please follow these step.,
check your internet connection, your cable wire if still working...crimp again the wires,if still not working. check if you have and intenet service provider of service connectivity ok. call your ISP. next check if modem is working. observe it there is a LED correspond to the words which ios the connectivity. lastly your IP configuration check it if you have aasigned a Ip addrss manualy or automaticaly.
Oct 08, 2009 | Acer Aspire 3000 Notebook
FN + F2 did not function in my ASUS laptop.
Restart> press F2 on boot = BIOS
Wireless device > ENABLE
Mar 14, 2009 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Reset my wireless asus wl-330g ip
Due to the different modes that the unit can operate in I suggest that you take a look at the user manual. The index for the numerous manuals is at the following link;
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=WL-330g
it seems that the magic number is 5 seconds, but it depends on what type of reset you want!
Nov 04, 2008 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Limited or No Connectivity
Yes, the wireless adapter can be fixed, by replacing the motherboard.
Jun 09, 2007 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
ASUS WL-330G 802.11g/b (wl330g) Wireless Access Point Logo
260 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
