Question about Zanussi FJS1225W Front Load Washer
Zanussi FJS 1197W washing machine main bearing
I am trying to replace main bearing. Can I do this without removing complete drum? Any tips appreciated
  • 54 Answers
Sorry you will need to remove drum
Posted on Feb 14, 2008
Replacing drum bearing on a ZANUSSI FJS 874 front loader ?
This is not a simple job, it can be fine but requires the complete disassembly of the machine to change the bearings, there are 2 bearings and a seal that require replacement, I can assist in guiding if you wish to do so, it takes around 3 hours total to strip and rebuild.
Jun 16, 2016 | Zanussi Washing Machines
Have just bought a zANUSSI fjs 1225 W. Have run one cycle ( quick wash, 40 degrees, cotton) and the fabric conditioner was not drained away. Is this because it was a quick wash? V disappointed as I need a...
zANUSSI fjs 1225 W. Have run one cycle ( quick wash, 40 degrees, cotton) and the fabric conditioner was not drained away This video will show you how to keep your soap draw clear and how to service the parts Please remember to subscribe to our YouTube channel for all appliance tutorials a 4 THUMBS rating is appreciated for answering your FREE question. And don't forget to like us on facebook
Feb 15, 2011 | Zanussi FJS1225W Front Load Washer
Zanussi 1400 jet model nowjd1457w ball bearings have come out
If ball bearings have come out, then there are only 2 possible places they could have come from.
1- The motor bearings.
2- the main drum bearings.
In both cases, it is a expensive fault to rectify.
To check, remove drive belt, and spin drum by hand, this should help you to tell if it is the main bearings or the motor.
Dec 16, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Replacing drum bearings, how to remove?
They come complete on spider assembly on some models..Check utube video. Or espares.co.uk for parts cost 1st...
Oct 07, 2009 | Washing Machines
Clanging noise out of the machine when going through the spin cycle. The noise gets worse as the spin speed increases. Are there bearings that can be replaced ?
It could be a number of things. Anything from drum bearing failure to something as simple as a coin becoming trapped inside the tub under the drum.
More info here
Jan 06, 2009 | Zanussi FJS1225W Front Load Washer
Removing/replacing main drum bearing on a zanussi WDT1085
Yes you do need to remove the drum, it entails stripping the washer down, and it is normal practice to replace the complete drum half with the bearings pre-fitted..
It is not a job to undertake, unless you feel competent to do do it, as it entails al ot of work and time..
Good luck if you decide to proceed.
Plz rate my suggestions.
.Thanks.
Jan 03, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi FJS1197 w ashing machine making knocking noises when spinning
There is an answer at this link:
http://www.howtomendit.com/answers.php?id=16357
"some you can get at and some you have to lift over the top, when you get there you will need to smack the bearings out, maybe a old socket set with a long tube just to fit inside the bearing hole?. for what its worth go to the tip you might find one, that just wants a door seal?"
You must have some technical experience.
good luck!
Jan 02, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi aquacycle 1200
May be the Bearings.Open door and try moving drum, hold at top of drum and pull foreword and back if drum loose main bearings gon. Replace bearings.
Slim Jim
Oct 28, 2007 | Zanussi FJS1225W Front Load Washer
Replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Aug 29, 2007 | Zanussi FJS1225W Front Load Washer
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Apr 26, 2007 | Zanussi F1045W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
357 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
