Question about Kyocera RI-3530 Black and White Copier
How to repair with Toshiba copier 2060
Display : "insert key copy counter"
  • Prakash Dangi
    Prakash Dangi Dec 07, 2013
    display shows : The drum is not set Insert the drum.
    Problem Solver:
  • 17 Answers
Lan lam... "insert key counter" means that the machine has an external control device. Usually a small box the size of a pack of ciggerettes or smaller) with a mechanical counter that needs to be inserted into a port on the machine in order for it to operate. Companies used this to "control" and/or track machine usage by department or person. It may be that your machine has one but it's not inserted well enough, or you are missing the counter comepletely. If you don't have one of these control devices, you will probably need a certified technician to come out and disable this feature.
Posted on Oct 12, 2007
  • 43 Answers
Try turning on the copier while holding down the 0 & 8 keys at the same time, then type in 59 pres start, make sure it is set to 0 if it isn't, press 0 then interrupt, turn the copier off then on.
i hope this fixes your problem
Posted on Mar 02, 2008
When a service call condition occurs, SC codes are displayed in the copy
counter. The first three digits are displayed in the copy counter. Hold down
the "·" key to display the last two digits.
When the copier detects the E507 condition, "E-5" is displayed in the copy
counter. Hold down the "·" key, and "07" is displayed in the copy counter.
Jan 28, 2011 | Office Equipment & Supplies
How is e-studio 230 re set the copy counter
Reset the status counter
(1) The following processes are carried out after completing repair of the cause for the C41 error
(2) Press the [0] and [8] keys simultaneously to turn on the power.
(3) Input 400 using the numeric keys, and press the start key.
(4) Change the displayed status counter from [2] to [0], and press the SET key (Reset C41).
(5) Turn the power on again, and check that it returns to the normal standby mode.
Let me know your result.
Nov 17, 2010 | Toshiba e-Studio120 Copier
I have black strip running top to bottom of copy. Machine has 65,520 copies on the counter
What type of copier? A professional grade or SOHO AIO? Check the glass where the copies take place, including where ADF copies, make sure there are no debris. If you can look to see if there are any debris or faults in the scanner assembly. If that's ok it could be many things. If it is a higher end copier it could be as simple as dirty corona wires or as bad as a worn drum.
Dec 18, 2009 | Toshiba 2060 Copier
Toshiba 2060 problem with casette
If the cassette makes a popping noise when first inserted (as it tries to lift paper to feed rollers) then the lift motor drive case is cracked / of the gears may be also damaged.
Sep 09, 2009 | Toshiba 2060 Copier
Toshiba 2060 Photocopier prints copies that are a bit too dark.
restart the copier while holding down the "0" and "5" keys. you will now be in service mode. enter "5" and press "start" key a number should show up in the display. this is the exposure value - how dark or light the copies will be. 5 is the automatic exposure setting. around 128 is the normal value. the larger this value the lighter the copies are - the smaller the value the darker the copies.
Enter a new number (exposure value) and press the "interupt" key to save the value. Restart the copier and check what the copies look like. Keep adjusting until it looks good/better.
Mar 26, 2009 | Toshiba 6560 Copier
Random C21 in Toshiba 2060
Dear sir; the toshiba copier they store the desciption in the memory therefor you just press "8" and "clear/stop" key simultaneously, It might be resetable, just turn machine off and back on. if you need more help please let me know,
Dec 17, 2008 | Toshiba 2060 Copier
How to change developer on Toshiba 2060 copier?
Changing the developer is a procedure for service technicians to do.  You might want to ask that question on  There are Toshiba service technicians on that can help you with that.
Sep 13, 2008 | Toshiba 2060 Copier
Toshiba 2030 copier machine
hi Shailesh,
i have never heard of a Toshiba 2030 is it a eStudio 230?
Apr 10, 2008 | Office Equipment & Supplies
Toshiba 2060
i would buy new lazor toner 1st cartridge to see if yoru s bad or out
Jan 19, 2008 | Toshiba 2060 Copier
Kyocera RI-3530 Black and White Copier Logo
368 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
