Question about Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660
Hi can you help ? when i try to put mine pin number like if i press number 1 light number 3if i press number 9 light number 6 and the done bottom and back bottm is frozen can you help ? regards
Update to 4.10 software. I had simular problem but after updating it was solved.
Posted on Oct 11, 2007
My garmin nuvi 660 is frozen . how can I do?
Reset the nuvi 660:
1 Disconnect from external power.
2 Flip antenna up.
3 Locate and press small button labeled "RESET" in the antenna recess on rear of nuvi 660.
4 Connect to external power source.
The nuvi will reset, power up and operate normally. If this was helpful, please rate it 4 thumbs up - thanks & good luck!
Sep 20, 2011 | Garmin Nuvi 660 GPS Receiver
Help me.......i put a pin number on my garmin nuvi 660..and i cant remember what it is...Is there any way to reset it and start over..
All you have to do it take the gps back to where you were when you entered the pin # . It will then start up and you can either change the pin or just set it to where you won't have one .
This is done so that when IDIOTS steal them , they can't do ANYTHING with them,
Dec 13, 2010 | Garmin Nuvi 660 GPS Receiver
It is locked need a pin
The only way is to take it to Garmin or goto the location that you create you PIN this will unlock it.
Oct 13, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin c550 phone book problem
Garmin support center----tomtom support center
http://www.gpscentral.ca/contactus.htm
all the gps information for 660 number model
http://gpsinformation.info/nuvi/660/660.html
just model number is different but the system is same
hope this helps
Nov 25, 2008 | Garmin Nuvi 660 GPS Receiver
Ribbon cable for nuvi 660
u can get it at radioshack websites
or u can try this link above
Nov 16, 2008 | Garmin Nuvi 660 GPS Receiver
Cant enter pin or screen is frozen
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 11, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin 660
If you start it up and are located in the place where the pin code was set, then the unit should unlock once it acquires sufficient satellite signals.
Sep 05, 2008 | Garmin Nuvi 660 GPS Receiver
Unlocking security code
The first thing you have to do is enter the correct PIN or take the unit to the location at which the PIN was set. It will now unlock. You can then press the icon that looks like a wrench, and look for an icon that says Garmin Lock (it is in different places on the different units, and I forgot exactly where it is on the 660, sorry.) You can then change the security code from there. If you are trying to unlock the unit without the PIN number, you will be unable to do so without taking the unit to the security location. In that case, your only option is to send the unit to Garmin.
Jul 25, 2008 | Garmin Nuvi 660 GPS Receiver
Hi can you help /
You can try a master reset. With the unit off hold your finger on the upper right hand corner of the touch screen and tap the power button.  Continue holding your finger on the screen until you see a message "This operation will erase all waypoints, do you want to continue?" (this could take up to a minute)
Tap yes and the unit should reboot then attempt to acquire satellites.
Oct 09, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660 forget my pin
The only options you have when it comes to a locked unit is to enter the correct PIN, go to the location where the PIN was set, or send the unit back to Garmin. There is no way to unlock a PIN locked unit without the correct PIN or location.
Jul 29, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
82 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
