Question about Garmin Nuvi 660 GPS Receiver
Hi can you help /
My nuvi 660 work find load the maps but when i am put mine pin number if i press number one it light number 3 and if i press number 6 light number 9 and the done botton and back bottom is frozen . Regards
Hi thank you for your help.
I have to send it to Garmin Uk it need recalibrate the screen.
thank you all who try to help me
Regards
Posted on Oct 28, 2007
    Novelist:
  • 113 Answers
You can try a master reset. With the unit off hold your finger on the upper right hand corner of the touch screen and tap the power button.  Continue holding your finger on the screen until you see a message "This operation will erase all waypoints, do you want to continue?" (this could take up to a minute)
Tap yes and the unit should reboot then attempt to acquire satellites.
Posted on Oct 25, 2007
  • Anonymous Oct 27, 2007
    Didn't work?  What happened?
  • Anonymous Oct 29, 2007
    Please log in and change the rating to "thanks for trying"
SOURCE:
My nuvi 660 turns on but displays "loading maps"
The problem is that the nuvi 660 gps receiver is jammed and needs to be reformatted.
What you have to do is to disconnect the gps, and connect it to a computer, then format it.
After formatting it, you download the self extracting archive files for your nuvi on to your hard drive, then connect your nuvi to a free USB port on your PC interface cable and allow your nuvi to initialize and enter USB mode, Unzip the files by running the downloaded executable files, then follow the instruction provided by the launched update application on your PC.
Then install it back in your car and turn it on, it will work once again.
Take care and good luck
i hope this helps?
Dec 05, 2010 | Garmin Nuvi 660 GPS Receiver
Corrupted the software
It depends on how the files were corrupted. If the source of the corruption is not physical or magnetic damage to the memory chip where the software is stored, you should be able to reinstall the operating system software and the new maps right from your own PC.
First I would recommend going to the Nuvi 660 page in the Garmin website, look for the link to "downloads and updates", and download the most recent software update. The update is free.
Once you have done that, try reinstalling your maps. You can only load Garmin maps into your Nuvi.
If you are in the US and your memory storage is not damaged, I can update your GPS and install the map for you if you prefer.
Jan 05, 2009 | Garmin Nuvi 660 GPS Receiver
Cant enter pin or screen is frozen
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 11, 2008 | Garmin Nuvi 660 GPS Receiver
UNLOCK
1. Enter the correct PIN.
2. Go to the secure location where you set the PIN and the unit will not ask you for the PIN.
3. Send the unit back to Garmin to be unlocked.
I have had sucess in unlocking Nuvi's but I will only do it for owners who can prove ownership through a valid sales receipt and proof of ownership through registration through Garmin.
- Jim
Aug 24, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi 660
Spell county? Never seen a county option on a GPS. Usually its zip or city, street, street number.
Apr 28, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi 660
my nuvi was working great til last week when for some reason it would not load maps, get stuck on the first screen and then just shut down.
Jan 22, 2008 | Garmin Nuvi 660 GPS Receiver
Mapsource update CD
Hi check out this wed site, it will help. HT maps for the Nuvi are NOT for PC use. The map load onto the GPS as you install Mapsouce. Reinstall Mapsouce and take option 3 on the startup page of the program.
Good luck
Craig
www.gme.net.au/garmin/mapupdate/update2008.pdf
Dec 28, 2007 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 -- Loading Supplemental Maps
The best price I could find in the US for the
Euope maps was about $230 -on the internet - normal retail is $299. You have to buy and use it off the SD card, so depending on how long your trip is it might be more practical renting one, unless you want to try selling the SD card after you return.
Nov 07, 2007 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 MapSource
Henry,
You cannot replace American maps with European maps.  Garmin does this in order to protect the European retailers.  The European SD card eliminates the need to load the maps into the 660, however, if you need to use the card slot to store extra data such as MP3s then you might be better off buying the 670.
Oct 28, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660
Update to 4.10 software. I had simular problem but after updating it was solved.
Oct 09, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
80 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
